On the 93, it is enclosed on the passenger side below and behind the glove box, not to be confused with the fresh air damper that is vacuum controlled. If your heating controls are manual (cable controlled) follow the cables from the back of the selector console and they should lead you to the where you want. On mine, it was a cable and about 3/4 along the way there was a rectangular plastic protrusion from the cable that needed to be inserted into an assembly on one of the heater passages.
