93 Legacy will not startimdoha817 12-12-2004, 08:29 AM I have a 93 legacy 2.2 AWD wagon with around 230,000 miles that will not start. Started fine the day before,drove home from work no problem.Next morning tried to turn over but wouldnt.Brand new plugs and wires and new timing belt.I was thinking fuel pump? As far as i know it has never been replaced. Ideas? Will2 12-13-2004, 05:05 PM Sounds like you need a new battery imdoha817 12-15-2004, 08:46 PM forgot to add.. battery is brand new as well. Will2 12-16-2004, 06:00 PM Than it's probably your alternator Mendari 12-16-2004, 09:08 PM Then it's probably your alternator If your lights still turn on then you might need to inspect the starter motor and all of your fuses. If your lights are dead, then I aggree with Will2. If you have a car alarm then make sure it's not disabling the vehicle. Will2 12-18-2004, 06:28 AM Lights will come on even with an almost dead battery, most times( of course very dim). It doesn't take as much 'juice' to run lights as it does to turn an engine over. But I'm all for doing the cheaper things first. The question would be. Why isn't there enough juice in a'brand new battery' to turn the engine over? ByronP 12-21-2004, 12:15 AM If it has a newer battery and it still has trouble turning over i would agree that it might be the alternator. I've gone through two of them(212K miles) so far. Fortunately they are relatively easy to change out. ByronP Mendari 12-21-2004, 02:25 PM If the battery is fresh and the car will not turn over, then it is either the starter, the starter solenoid, or an ignition solenoid that connects to the key. Will2 12-22-2004, 06:50 AM I believe the statement was made that the motor"tried to turn over" meaning,to me, that the starter was working. There was just not enough"juice" in the battery to do it. To me that means the starter and ignition are ok. imdoha817 01-01-2005, 05:36 PM wanted to let everyone know,the trouble was the idler pulley was bad.Hopefully no more trouble for a while. kz1man 12-09-2008, 10:31 PM Hi; Your out of time! when you installed the timing belt you MUST! use the rear mark on crank gear. The gear has a front marking arrow,this will NOT work to time the engine. Hope this helps. Automotive Network, Inc., Copyright ©2012
