Re: 455 in an '86 LeSabre?
I swapped an Olds 455 into an '81 Cadillac Fleetwood, which, as you know is virtually identical to your hearse in terms of chassis design and dimensions.
It is an easy swap, especially since your 307 is an Olds engine as well.
The engine will bolt up to the transmission, which is half the battle.
Use 455 engine mounts. You might have to weld them in place on to the existing frame.
The stock radiator will work in the stock position. You would need a new exhaust around the engine. Olds engines used this strange system where the left manifold exhaust runs beneath the engine then sweeps up to meet the right side, so plan on a bit of exhaust work. Consider true dual exhaust throughout, anyways. The stock 307 pipe amd muffler may be a bit restrictive.
Use the 455 accessory brackets. The rest is relatively minor details, such as adapting the 455 carb and ignition to work with your existing systems. Is your '86 EFI or carb. If its carb, its lots easier to work with.
"We' re all here because we're not quite all there."
I still say a church steeple with a lightning rod on top shows a lack of confidence
