Drivetrain ?Pipemitten 12-09-2004, 03:45 AM When performing a Turbo swap from the 7mge to the 7mgte engine WITH TRANNY, will you have to replace the exsisting driveshaft? projectsupramk3 12-09-2004, 08:28 AM Yes, slightly different lenghts and a different number of splines. Pipemitten 12-13-2004, 02:51 AM you said slighty longer. and different splines. How about on the differential side. are the spliens the same. Or will I have to replace that too? projectsupramk3 12-13-2004, 10:32 AM The differential sides are all the same, it's four bolts. The gears inside the differential are different however, your going to be stuck with a 4.3 final and probably an open diff if you don't have the sport package. Pipemitten 01-02-2005, 03:18 AM nah I have the sports package with the lsd so that hsouldn't be a problem. Where's another question kind of off topic but w/e. Does anyone know of any reputable engine suppliers that would carry the 7mgte with tranny ,ecu and wireness for not too too expensive? Automotive Network, Inc., Copyright ©2012
