1998 JIMMY front end pop.....>>>>>>
bigbadbowtie
12-08-2004, 01:21 PM
Front end pops after sitting for extended period. Usually pops 1st thing in the morning while backing up and turning out of garage.
What has been replaced up front.....
Motor mounts
upper/lower ball joints
idler arm
Tires
The control arm bushings look ok,torsion bar mounts look good.
GM dealer could not figure it out either. (I don't trust them either.)
Any suggestions are greatly appreciated
Thanks
Ray
xokayxo
12-09-2004, 01:06 AM
when i turn hard left after my jimmy's been sitting it pops. '98 sls. you?
BlazerLT
12-09-2004, 01:47 AM
Hood washers need to be installed.
swalt
12-10-2004, 08:46 PM
Hood washers or this. Easy to tell if the crossmember is hitting the frame as there will be marks in the dirt on the frame.
Affected Models:
1998-2003 Chevrolet S-10, Blazer
1998-2001 GMC Envoy, Sonoma, Jimmy (US), and Oldsmobile Bravada
1998-2003 GMC Jimmy (Canada)
Some owners of the listed vehicles may experience a clunk noise that can be felt through the floor pan
This condition may be caused by the torsion bar crossmember contacting the frame rails during left or right turns or on uneven surfaces.
Determine if the clearance between the left frame rail to crossmember and right frame rail to crossmember are equal. If not, install either a washer or alignment shim between the upper mount and frame.
Refer to SI document 539243. This document includes a component diagram of the torsion bar crossmember to frame rail assembly and may provide assistance in the repair.
- Thanks to GM Technical Assistance
BlazerLT
12-11-2004, 06:23 PM
I would go with the hood washers first.
xokayxo
12-12-2004, 09:15 PM
i did the hood hinge washer and it hasnt clunked since. this is completely different, coming from the drivers side.
swalt
12-12-2004, 09:38 PM
Loose ball joints will cause a clunk on turns. I had mine replaced and it would still clunk. Next step was to shim the torsion bar crossmember with a washer so the crossmember had even spacing on each side between the frame rails. In my case, I could see where the crossmember was making contact with the frame by the marks left on the rail. My turning clunk ceased after the shim correction.
BlazerLT
12-12-2004, 10:25 PM
Greased your front end lately?
There are 11 grease fittings on a 4x4 s-series.
xokayxo
12-19-2004, 03:55 AM
zerks? greased those when i changed my oil and i couldnt find all 11. only 4 or 5 i think. maybe 6. didnt change after i did that, even.
BlazerLT
12-19-2004, 09:11 AM
What were the ones you greased?
swalt
12-19-2004, 11:48 AM
Add two more grease points if you have had your ujoints replaced. Factory ujoints are sealed. Replaced units come with zerks.
rlith
12-19-2004, 01:04 PM
Grease points
Top and bottom ball joints (both sides) Total 4
Idler Arm - 1
Pitman Arm - 1
U-Joints (If aftermarket, OEM don't have zerks)
Tie rod arms - 4 (inner and outer both sides)
BlazerLT
12-19-2004, 01:17 PM
There is one also on the main steering arm coming from the rack.
All need to be greased.
rlith
12-19-2004, 01:21 PM
Yes it's called the PITMAN ARM
BlazerLT
12-19-2004, 10:03 PM
Ok, so there are two pitman arms to grease.
rlith
12-19-2004, 10:37 PM
you only have 1 pitman arm 1 idler arm, that's it. The main steering one is the pitman arm
bigbadbowtie
12-20-2004, 09:01 AM
Sorry for not replying back..... had PC issues.
Ill check what yall posted about the hood washers and torsion bar
Ray
webrebel
02-05-2005, 10:16 PM
Where would I find this document?? Thanks
swalt
02-06-2005, 07:06 PM
Its a dealer document. Some dealers will share it with you, some won't. Some dealers get their backs up when you walk into a dealer quoting a specific document....like you know their "secret bible" or something. Not sure where you are, but at Partsource here in Ontario, you can download TSB's from a kiosk in their store.
webrebel
02-06-2005, 07:12 PM
Figures....most are clueless how to fix anything but they dang sure don't want you to know either...
