93 S-10 Starting problems
macerone9
12-07-2004, 05:42 PM
I have a 1993 s-10 Blazer Tahoe LT- Problem is long crank before starting... the engine will crank over and over for a good few seconds before it initially starts, once it starts it runs great. Shut it off and wait just a few minutes or less and try to restart and it starts right up, anything longer than 10 minutes or so cranking problems again. if i leave it for a couple days without starting it starts right up. I have changed the starter/wires/cap/rotor/plugs/battery. Fuel pump runs but i think the problem is some sort of fuel problem. please let me know if you've heard of a problem/solution similar. thanks!
CokeandCandy
12-07-2004, 07:37 PM
Have u replaced the fuel pump? Check to see if the fuel pump hums if it does u need to replace it.
Good Luck
Mikado14
12-08-2004, 10:42 AM
Good Luck
Before you go changing out the pump you should check the fuel pressure. Also, when was the last time you changed your fuel filter?
macerone9
12-08-2004, 05:30 PM
I know the fuel pump is working properly- I had other people tell me it might be a pressure problem, Ill see about changing the fuel filter. Is there any way to check for pressure problems easily (mainly some sort of vacuum affect.)
Fractured1
12-08-2004, 06:07 PM
The only true way to test the pump is with a fuel pressure gauge...it connects to the schrader valve on your fuel line..
BlazerLT
12-09-2004, 02:50 AM
CPI injector is leaking.
Open up your upper plenum and look for washing from gas spraying.
macerone9
12-09-2004, 06:07 PM
I'll give it a shot this weekend, but i dont think its leaky injectors because after 48hours+ it will start right up no problem. Thanks
Fireplug
12-09-2004, 07:51 PM
Changing a starter for a long crank time is a waist of money also changing battery waist of good money.
LONG CRANK TIMES ARE 9.9999999 TIMES FUEL PRESSURE PORBLEMS.
BlazerLT
12-09-2004, 08:19 PM
Just because it will start up perfectly now doesn't mean the injector is fine.
It will sometimes work, and sometimes not.
macerone9
12-10-2004, 06:00 AM
I understand what your saying, only problem is the long cranking problem has gone on so long that the starter went and would just click when I tried to start and the battery was replaced before any problems came up, it just needed to be replaced.
