Check Engine Light Code 0404whosgreg 12-07-2004, 10:08 AM 2002 Saturn SL Saturn dealer said the oxygen sensor was defective. I replaced the sensor. Check engine light came back on. Took it to autozone and their OBD II showed code 0404 related to EGR. Their book is showing 9 possible problems from EGR. Help! anyone having this type of problem? Thanks sierrap615 12-08-2004, 12:31 AM DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance most EGR problems can be solved with a good cleaning, remove it and spray inside the EGR and the passages inside the head with sensor-safe carb and choke cleaner. replace the EGR gasket also, its $5 at saturn whosgreg 12-10-2004, 08:58 AM Thank you for the suggestion. I tried it after reading your message. The light and code still came back. Any other suggestion? sierrap615 12-11-2004, 01:09 AM sorry, thats the only easy tip i know of, take it to saturn for diagonistic. greatfullydeadend 12-11-2004, 06:21 PM Did you reset your computer to erase trouble codes after you cleaned the EGR? whosgreg 12-13-2004, 07:57 AM Yes, I did. Thanks Did you reset your computer to erase trouble codes after you cleaned the EGR? Automotive Network, Inc., Copyright ©2012
