86 16v sunroof leak
chall200
12-07-2004, 09:37 AM
Water leaking down (Somewhere) causing the driver's side seatbelt to become wet, as well as water leaking down to the floor behind driver's seat. Have had the sunroof out a few times and checked the drains as well as the drain tray. Drain tray seems to be aligned right and the drains (front and back) seem to be clear. Wondering where the rain water is leaking down through?
boschmann
12-07-2004, 09:38 PM
How is the weatherstrip around the door & on the body above the door. They commonly deteriorate.
chall200
12-11-2004, 09:04 AM
Weather stipping is good. Can't figure it out. My friend who has an '88 had the same problem but he doesn't know how he fixed it. Said he had his sunroof in and out about 25 times. Seems to only leak when the car is level or ass end slightly on the decline. If I keep the car with the nose slightly on the decline it doesn't leak.
boschmann
12-12-2004, 09:34 AM
It sounds like the rear sunroof drains are clogged.
deletedalien
05-21-2005, 10:33 PM
Actually the rear drains are clogged it happened to me once and it happened to a friend of mine as well
check the drains inside the rear bumper on the sides there should be a litthe white rubber hose thats about 1/4" and sticks out about 1" with a 45degree angle cut and if you raced trough mud then its definetly glogged and the way to unclogg it is using an old antenna and pressureised water from the inside of the sunrooof to the back untill it comes out trough that little hose (i know its a lot of work to dissasemble the sunroof but what are you gonna do?)
chall200
02-28-2006, 05:48 PM
Thanks guys... I finally found that the left rear drain was clogged. That seems like the culprit. Have to wait and see after the next rain storm! Thanks again. Totally forgot about this forum question I posted a while back!
crazy_dude88
08-19-2007, 10:23 PM
Hi. I was just wondering if you can help me. My sunroof in my 88 scirocco does not operate, and I cannot find anything to help me or tell me on how to take it out to find out that the problem is. How do you take the sunroof out to service/fix it???????
Ryan
