shaking while at idlecubanlorenzo 12-06-2004, 11:58 AM 1995 4wd 4.3 cpi blazer. while at idle my car likes to shake a little. the idle doesnt move from 750. but my car shakes a little, kind of annoying. what do you think? TonyMazz 12-06-2004, 02:30 PM 1995 4wd 4.3 cpi blazer. while at idle my car likes to shake a little. the idle doesnt move from 750. but my car shakes a little, kind of annoying. what do you think? What have you done to the vehicle so far ? I'd suggest doing a few things to even out the idle....like Like - Cap, Rotor, Plugs, Wires, PCV, Air Cleaner, Fuel Filter, sea foam in gas for starters..... Next could be, I suspect Timing, EGR cleaning.... I have a newer blazer (99) so the timing is always set by the computer...but these are things I'd start with.... chcknugget 12-06-2004, 07:17 PM Isn't the harmonic balancer supposed to keep the shaking down at idleing? Just asking. cubanlorenzo 12-06-2004, 11:35 PM i just did a full tune up. just bought a egr valve 2 months ago. i was going to change my pcv valve tomorrow rlith 12-07-2004, 07:41 AM Have you checked your CPI and nut kit? Might be starving a little fuel (enough to shake, though with your idle steady I'm not sure about that) Also take a look at your motor mounts. The may be farked and it's allowing the rocking in your motor. TonyMazz 12-07-2004, 10:37 AM i just did a full tune up. just bought a egr valve 2 months ago. i was going to change my pcv valve tomorrow So...how many miles on the truck ?... When you did a "Full Tune up" what does that mean exactly...... Did you change the wire sets.....maybe you have a bad wire....without knowing what you did in your tune up we are only guessing...so tell us more !!!! :rolleyes: BlazerLT 12-07-2004, 12:49 PM Have you checked your CPI and nut kit? Might be starving a little fuel (enough to shake, though with your idle steady I'm not sure about that) Also take a look at your motor mounts. The may be farked and it's allowing the rocking in your motor. He replaced the CPI and nut kit about 2-3 months ago. All Blazers are not perfectly smooth running engines. cubanlorenzo 12-07-2004, 01:31 PM 183000 miles. that could be why. wires, plugs, rotor, cap, fuel filter, oil change(mobil 1), oil filter, air filter, 02 sensors. everything and anything. it isnt that bad of a shake, just a little tremble. not too bad that i will go off and spend 500 bucks to fix. thanks anyway everyone. rlith 12-07-2004, 01:32 PM check the mounts BlazerLT 12-07-2004, 05:03 PM Replace the pcv valve also. Automotive Network, Inc., Copyright ©2012
