Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Civic > '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV
Old 12-05-2004, 09:09 PM   #1
honda4u
honda4u Normal reputation
Send a message via AIM to honda4u
horsepower?
Does anyone know how to get a lot of hp with out tubro or supercharging your car?
honda4u is offline   Reply With Quote
Old 12-05-2004, 09:50 PM   #2
CivRacer95
srs biznis
CivRacer95's Avatar
CivRacer95 Normal reputation
Send a message via AIM to CivRacer95
Re: horsepower?
Yeah, get one of those electric superchargers off ebay . Then add headers and exhaust and you'll be runnin 9's at the track all day long... j/p. About the only suggestion I can give you is a motor swap. Otherwise you'd have to go with bolt-ons. I don't know of anything that can produce tons of horsepower without forced induction. Late...
AF Guidelines. Read and play nicely :
Just Click Here!
I Hope you like Pain
blazee = CivRacer95
CivRacer95 is offline   Reply With Quote
Old 12-05-2004, 10:00 PM   #3
Plastic_Fork
Plastic_Fork's Avatar
Plastic_Fork Normal reputation
Re: horsepower?
A good engine buildup will produce a good amount of horsepower, but don't expect to reach the same numbers you could with forced induction.
Bolt-on's and internals is the way to go for N/A motors. Higher compression internals will yield better performance, but be sure you reinforce the motor to be reliable under higher compression. Might want to consider a stroker kit or boring out the cylinders slightly for higher displacement and a more agressive camshaft(s). Engine management system and an improved fuel system will also be a good idea. If you want, individual throttlebodies is also an option.
Be sure to decide what you want out of the car first - that will decide what you buy and how you modify it.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Plastic_Fork is offline   Reply With Quote
Old 12-05-2004, 10:50 PM   #4
bingisSD
bingisSD's Avatar
bingisSD Normal reputation
Send a message via AIM to bingisSD
Re: Re: horsepower?
ya whatever he said.
good ideas for what to do first and what the end result will be is to ask someone down at the local drag strip. port/polishhed head, research and built bottom end, eliminate any unneeded pieces, pulley and flywheel size reductions. cams are a must. skunk2 intake manifold. there is a guy at the local strip who ran an 8.7 on the 8th mile in a del sol, all motor no nos. then he ran an 8.3 with nos, and after adding his turbo setup he ran a 7.9. so you are going to have to build up youre motor regardless.
There is tons of stuff do upgrade inside the motor, plus weight reduction plays a huge role, any given honda can lose at least one or two hundred pounds. that guy claims his del sol weighs 2000. though he did replace the windows with plexiglass and cut out the inside of his doors and stuff. going N/A is a respectable way to go with it, just dont count on being able to get all the stuff you need off ebay or kragen, it takes much more time to get to put out the same HP.
make sure to get that compression up and stable, and it youre not anti-NOS it should become 70shot capable
www.cardomain.com/id/bingissd
http://www.automotiveforums.com/vbulletin/showthread.php?p=2660831#post2660831 <MEET IN DAYGO
bingisSD is offline   Reply With Quote
Old 12-08-2004, 12:43 PM   #5
Lychus
Lychus Normal reputation
Re: horsepower?
dont over look any minor details when ur building up your motor. A good all motor company is Toda.
Lychus is offline   Reply With Quote
Old 12-08-2004, 01:29 PM   #6
CivicSiRacer
Civic Mod
CivicSiRacer's Avatar
CivicSiRacer Normal reputation
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: horsepower?
As most people said bolt ons (intake, header, intake) might net you about 10-15hp the most. It's not neck snapping power at all. Realize that you bought a Civic which is an economy car.
In order to get the most power for your $$$ you need forced induction OR a really well built NA engine (which could end up costing more money than FI).
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
CivicSiRacer is offline   Reply With Quote
Old 12-09-2004, 01:00 AM   #7
honda_luvr_2000
honda_luvr_2000 Normal reputation
Re: horsepower?
a little note. (i'm almost 100% sure on this) the ratings honda puts on their engines, is w/ power steering, A/C, and the alternator. so if u take off the A/C, and swap to manual steering (which isn't as bad as sum say) there's about 10-27hp. the wide range is all dependant on the motor & accessories u'r dealing w/. and that's pretty cheap hp if u ask me. u can get a used manual steering rack from a yard for around $100, and that's basicly the only thing u'd have to buy.
as for other exterior bolt-ons, yeah lightweight flywheel (not size reduced), lightweight crank pulley, BIGGER alternator pulley (YES BIGGER), CAI, header, REAL hi-flo cat, 2.25" catback (if u dealing w/ a D-series, 2.5 for all the others N/A) w/ straight thru exhaust and not loovered, intake manifold, bigger TB, cam gear/s. actually, stock Honda spark plug wires have tested BETTER than most aftermarket "upgrade" wires. even stock Honda spark plugs r not worth changing out, just get new ones. fuel mods eventually but not absolutely necessary by this point. the stock fuel pressure regulator will notice the better breathing of the motor, and will actually add more fuel than before. but nothing major.
honda_luvr_2000 is offline   Reply With Quote
Old 12-09-2004, 12:38 PM   #8
crxlvr
Slowest Automatic Civic
crxlvr's Avatar
crxlvr Normal reputation
Send a message via AIM to crxlvr
your not really making HP taking off the AC and switching to manual steering, your just freeing up the HP that the motor used to run the parts. same with underdrive pulleys and exhuasts and intakes. these productsz do not make HP they simply free up HP lost due to their stock restrictive design.
2007 Honda Civic
Proud Parent of Robert James.
crxlvr is offline   Reply With Quote
Old 12-09-2004, 01:37 PM   #9
honda_luvr_2000
Re: horsepower?
if u want to get technical, absolutely every bolt on mod, internal and external, is not really making HP. u'r just reducing restrictions on the motor. so yeah u'r right. so yes u'r only freeing up HP, but it's still a gain. either way they r upgrades for more resulting HP.
Bookmarks
Google
Web AF
