Transfer Case to Transmission Gasket1991Blazer4x4 12-04-2004, 10:06 PM Hey fellas, I recently pulled my Transfer case off of my transmission and it didn't have a gasket on there. When I go to put the transfer case on...do I put black RTV on the gasket then bolt it up? Just thought I would check with you guys so I don't make a mistake. Thanks Alot guys, this forum is awesome. BlazerLT 12-05-2004, 09:43 AM Do you know what you are doing? Does the job ask for RTV sealant? Is there supposed to be a gasket? Mikado14 12-05-2004, 10:12 AM Do you know what you are doing? Does the job ask for RTV sealant? Is there supposed to be a gasket? Ditto Original poster - If it didn't have a gasket on it, and it was never worked on, there shouldn't be one. There should be a seal on the tranny output shaft and one on the input shaft of the transfer case. A gasket would be redundant. However, a thin film of RTV wouldn't hurt/help. Go for it if you feel like it. 1991Blazer4x4 12-06-2004, 05:50 PM The Chevrolet dealership shows that there is suppose to be a gasket for the transmission to transfer case. There wasn't one on there though. That is why I was asking about the RTV sealant. BlazerLT 12-06-2004, 06:13 PM Then buy the correct gasket for it then. 1991Blazer4x4 12-06-2004, 06:15 PM I DID.....The question was whether or not to use RTV on it. BlazerLT..you sure do like to give some people hell but you have good advise. BlazerLT 12-06-2004, 06:19 PM Nono, I didn't give you hell, I just stated if it requires it, then installthe correct gasket for it, not RTV sealant. Automotive Network, Inc., Copyright ©2012
