uhhh ooooodomesticdisturbans 12-04-2004, 08:03 PM ok i need help when i start up my sl2 she has high miles 330,000 but any wayz so when i start here my oil heat gauge cranks all the way to hot then shakes between hot and cold i am starting to worry about it cause i thought it was all because of cold starts could that be the problem ? or should i give here another oil change any ideas or suggestions will be greatly appreciated ~shawn :confused: sierrap615 12-05-2004, 04:43 PM the stock gauge is coolent temp, did you install a aftermarket oil temp gauge? ether way, have you ever replace the ECT? domesticdisturbans 12-05-2004, 09:55 PM no i havent how much would one cost me? sierrap615 12-05-2004, 10:19 PM the only ECT i recommend is the brass-tip OEM sensor from the dealership, its about $15 http://www.saturnfans.com/forums/showthread.php?t=24003 Automotive Network, Inc., Copyright ©2012
