engine just dies after 20 min
thunder-phantom
12-04-2004, 05:06 PM
93 vortec w code new fuel pump,filter and cpi starts runs for 20 min and just dies wont start back up for hours
BlazerLT
12-04-2004, 05:14 PM
Does it run rough when it is running?
When it dies, have you checked for spark at the end of each spark plug wire?
thunder-phantom
12-04-2004, 05:32 PM
not running rough ,checked spark but not at each plug wire ,was running rough when i first started it after installing cpi but after a min running smouth
BlazerLT
12-04-2004, 05:53 PM
once it dies and won't start, check to see if you are getting spark.
rlith
12-04-2004, 07:09 PM
Sounds like the ignition module heating up and going dead. I would check t hat at least first off, then work my way around to a coil.
thunder-phantom
12-05-2004, 10:02 AM
ok ran for 20 min and died checked for spark at each plug has spark wont start
rlith
12-05-2004, 10:06 AM
again, try replacing the ignition module
It may be heating up and going bad
thunder-phantom
12-05-2004, 10:20 AM
ok well it will start on starting fluid so it must be a fuel issue
rlith
12-05-2004, 10:21 AM
did you replace the nut kit when you replaced the CPI unit?
thunder-phantom
12-05-2004, 10:23 AM
no but i only had washing on the passenger side
Mikado14
12-05-2004, 10:28 AM
Did you check fuel pressure after it died?
Have seen this problem on other '93's including my own. For some reason, the socket on the fuel pump relay becomes intermittent, metal fatigue in the connectors. GM sells, whoda quessed, an upgraded socket with heat shrink connectors.
When it dies, and you turn the ignition off and then back on, do you hear the pump prime? Have you tried to put 12V to the test wire next to the pump relay and the pump runs? If you answered no on 1 and yes on 2, look to the relay.
thunder-phantom
12-05-2004, 10:32 AM
yes it holds fuel preasure, and the pump is primeing
Mikado14
12-05-2004, 10:39 AM
If you have spark when it dies, the fuel pump is priming, it will start and die with a shot of ether, then your right, you have fuel issues.
The only other option is:
1. Defective CPI unit
2. Wiring issues to the CPI
3. ECM problems
rlith
12-05-2004, 10:53 AM
What's you're pressure at the shradervalve?
Mikado14
12-05-2004, 10:59 AM
On second thought, Ditto to rlith.
Original poster - your not just popping the schrader and assuming you have the proper pressure, are you?
thunder-phantom
12-05-2004, 12:34 PM
fuel pressure is 58 constant running or after it dies
rlith
12-05-2004, 04:09 PM
hmmm, should be 61-64 while running......I've seen worse though. When it's running how does the oil pressure look?
thunder-phantom
12-05-2004, 04:50 PM
oil pressure good 40 + always
BlazerLT
12-05-2004, 08:42 PM
good 40 + always
No, not on a CPI. Even 45-50psi will have the truck not starting.
The poppets require at least 55 psi to open properly.
On a 1993 Vin W, the pressure should be 55-61 psi with the key on and the engine off.
Lobo1
12-07-2004, 08:32 AM
Check engine coolant temp sensor. I heard that this is very common for the "engine dies when warm" condition, but I have no personal experience with the problem. Cheap & easy to try.
BlazerLT
12-07-2004, 11:57 AM
Nah, throwing random parts at a truck is not a good idea.
gbic1
12-07-2004, 12:23 PM
THis sounds familer. Did you check the plugs to see if flooded? Have you pulled off the plenum to see if it is flooded up there again? Where did you get your cpi unit?
thunder-phantom
12-07-2004, 08:15 PM
cpi unit is ac delco
thunder-phantom
12-12-2004, 08:35 PM
Well After A Month Of Playing With This Thing And Replacing Fuel Pump,cpi,ecm,plugs,wires,cap And Rotor, Today Put In A Ignition Module And Its Running....it Had Spark The Hole Time But Must Have Not Been Enough................thanks For All The Help
rlith
12-12-2004, 08:48 PM
Good to hear it!!! (Didn't I mention that in the 3rd message in this thread? (grin, just jagging ya) :) Glad it's all good.
BlazerLT
I Get A Kick Out Of People That Use Capitals At The Start Of Every Word They Type. Makes Me Horny....
