Installing my body kit....
space-monkey
12-04-2004, 03:34 AM
Ok i searched threds this isnt a repost. i Need some quick pointers. I have a body kit and z3 fenders for my 95. its a 97 front bumper so i will have to get new headlights. but what is the screw/bolt # onthe front rear. so i know before i start pulling? also readu have to take off the support. is it bolt on bolt off, or cut off. And side skirts, my rs did not comt stock how do you reccmoney installition... screwes? and what kind? or a glue? also drilling what size holes? and should i get washers? Just help me out.
EVOclipse
12-04-2004, 04:16 PM
no offense here but trust me this is something you probly really wanna have a proffessional do. the stuff can all be taken off pretty easy just buy a haynes manual...but let me tell u...fitting your kit back up together is a pain in the neck specially if u bought z3 fenders and skirts
EVOclipse
12-04-2004, 04:18 PM
hehehe yes i did the self install bumper
space-monkey
12-04-2004, 08:37 PM
Well im a poor college kid, so im just needing a bolt count kind of on the bumpers. like how to get em off.
coolguycooz
12-05-2004, 06:45 AM
Let me tell you something monkey. With that car. you cant get the head lights off without taking off the bumper and you cant take off the bumper without taking off the headlights. Really your screwd. Nah there is a screw thats facing upward toward the head light and its almost impossible to reach it can be done get a really tiny wrench . It will take you a good 10-20 min per screw. Actually if i remember right when i did mine i think i just cut my bumper off cause i got pissed off since i was doing the body kit for sure.
anarchy1114
12-05-2004, 04:25 PM
there should be about ten bolts that the 97 front will require. then there is a bolt behind the headlight in the engine bay , on top of the head light and one below it that can only be reached after you get the bumper off. you shouldn't have to remove the front support (big black piece of plastic inder the front bumper). the 97 front will cover it.
the fenders are going to have to bolts under the car towars the back of the wheel well and then 8 bolts, 4 on either side of the engine bay, and shares 2 bolts with the fronr bumper. and when you open your door there should be on behind the fender.
i'm not sure about the rear bumper or the side skirts.
1stGenRocks
12-05-2004, 05:28 PM
i would recomend doing the z3 fenders first and get them lined up right with the doors hood and stock bumper. then put on the new front. that way you dont have to line up everything at once.
anarchy1114
12-05-2004, 07:13 PM
:iagree: and fenders are a bitch to line up. i suggest that you have someone help you ... its alot easier with 2 ppl tryin to line 'em up than just yourself.
97_3clipse
12-05-2004, 07:53 PM
you can basically un-bolt the whole car with a 10mm and 12mm wrenchs (and maybe a 14mm if you want to get technical) ....fyi: there is glue holding the fenders to the engin compartment i think a heat gun can melt the glue pull it off...there are there are bolts holding the fener to the engin compartment, one holding it on the inside of the engin compartment (take off the air box to acess it) ,one or two in the door jam, and two at the begining of the side skirts(near front tire) take out all the bolts in the wheel well and your set (dont forget to melt the glue)...
gthompson97
12-05-2004, 11:59 PM
another point....the z3 fenders are a bitch to put on. i bought some and they didn't match up at all. i tried to fit them on and they stuck out at teh bottom so i softly pushed the bottom on and you could tell they were gonna break if i put them on and even bumped into my fender. i would have a professional that can work with fiberglass put them on otherwise you have a big chance of fuckin things up. just fyi
real_madridcf
12-06-2004, 12:20 AM
:1:
Im dont have a kit myself, but IMO dont do it unless you know what your doing. I dont think you want to be experimenting with something like that, but if you have the confidence then go for it.
Either way I wish you the best of luck!
space-monkey
12-06-2004, 02:30 PM
I think im going to take off my fenders line em up, then do the front bumber and get it on, then side skirts..... screws? then back bumper is ez, drill homes for it, bolt on, and wire lights. ive done a few kits on some hodas but none on these damn dsms, wth the complicated front bumper
gthompson97
12-06-2004, 04:47 PM
i can almost gurantee you it wont' be that easy. if the bodykit isn't 100% perfectly manufactured which im' sure it's not, you'll have complications. there are gonna be edges that don't line up and pieces that don't line up right or aren't shaped right or something.
