93 civic cx with dx motordumped93civic 02-28-2002, 10:44 PM I was needing to know if a 93 dx motor would bolt right into a 93 cx? WOuld the tranny bolt up and what all would i actually need to swap since neither is vtec? Also, would the dx motor hold up if it was sprayed or turboed? Thanks in advance 90CRXZCSi 03-01-2002, 12:02 AM Yea everything will work fine as for the motor bolting up. It will just end up being like a DX hatch. The tranny will bolt up but i wouldnt recommend using it unless you only wanna beat school buses like sparq said. The motor will be allright for a 55 shot of NOS or a small turbo but you will want to build up the motor a little bit . Oh and also make sure you get the DX ECU. praxis 03-01-2002, 10:39 PM Yeah, it may be an upgrade...but I think you are wasting your time and money. For about the same cost you could get a much better engine/trans. for your CX. Regardless, if you are getting a good price on the engine...you would be much better off (in the long run) to either save and get what you want or put it on plastic. juncivicls 03-03-2002, 04:02 AM the cx has a one wire o2 sensor and i think the dx has a 4 wire but anyways buy a b series motor. kane2g 03-07-2002, 06:01 AM the swap will be flawless. the tranny will be a dog, because it has really long gears, so dont expect racing w/ it, but its great for long distance trips. I would suggest maybe gettin a EX engine which will bolt right in too and you can pick one up relativly cheap about 500 or so. Automotive Network, Inc., Copyright ©2012
