bigger tires
beastlyblazer89
12-02-2004, 10:47 PM
i got an 89 s10 blazer that has 235/75/15 tires right now and with a stock suspension could i run an aggressive 30/9.5/15 with no mods or if i was to do a 3 inch body lift how big cud i go and i was wondering what a good brand body lift that will come with everything i need.
thanks.....
Blazing Rice
12-03-2004, 03:38 PM
The 30s will fit, assuming you are using stock offset wheels. I run that size on my 92 and have not experienced rubbing or trimming either.
s10blazerman4x4
12-03-2004, 05:34 PM
so what you are sayin is on my 91 i could put 30s on if i have 235 75 15 cuz that would be kool
BlazerLT
12-03-2004, 09:52 PM
You might get some rubbing while turning.
rlith
12-04-2004, 11:50 AM
With stock on both my 1st gen (3" body lift) and my second gen (no body lift) I've run 31x10.5's and not had any rubbing probs...
beastlyblazer89
12-04-2004, 02:05 PM
by second generation do u mean like 95 blazer and newer? iu said that u put a 3 inch body lift on it how hard was that to do and what does it require me to do extra?
rlith
12-04-2004, 07:03 PM
second gen=95 and up, with out a body lift you can easily do 30x10. Body lift install was pretty simple. I used the Trailmaster 3" body lift kit. Comes with everything. only 2 things you need to do is weld the extention onto the shift linkage (unless you switch to center shift which is what I did) and add the extention to the gastank filler neck. Both these parts are included in the kit.
