B16A non ODB
shatshadarach
02-28-2002, 08:48 PM
hey, im workin on my b16a swap on my 89 civic si...the wiring on my motor was cut, so all i got is two clumps of wire coming off each side of the engine (typical), i went through it all and figured out which wires goto which sensors, but the problem is, is that i dont know what the sensors are called so i can wire them up to my ecu correctly...is there any site out there or any one who can give me a visual of what the sensors are on the motor??...any help would be great, thanks
5_LiTeR_EaTeR
03-03-2002, 12:09 PM
so the wiring got cut on the b16? I think you are suppose to use the old harness from your old motor.... well thats what I did. And if it is cut you really don't want to use it because you are going to have a hard time splicing all the shit together. What I did was use my old harness from my d16a, extended like 1 wire, then ran 4 wires straight from my ecu to:
Vtec Solenoid
Vtec oil pressure switch
knock sensor
secondary 02 sensor
If you want you can send me pictures of the sensors or explain where it is and how it looks and I will tell you what it is. it really isn't that hard once you get used to the meaning and use to alot of the sensors. You can Email me at Wildfire7777@hotmail.com for any other questions and I will be glad to help you out.
shatshadarach
03-03-2002, 01:18 PM
youve got mail
