95 Escort Hot Engine Start ProblemBrokenWheel 12-02-2004, 08:03 PM Greetings FordDrivers, I have a 10 year old driving relationship with that car and we had ups and downs as typical. Now I decided to take care of it myself instead giving it blindly to a mechanic or at least know about the origin of the problem. Now I have a problem. It usually occurs during the winter ( cold season). After driving (about 40 minutes) I park a car and go shopping or elsewhere for an hour or half an hour but not less. When I go back to my car, I have a problem starting a car again as if ignitors are bad. When it finally starts (after 3rd or 4th try) the engine chokes. A lot of stuff has been replaced. Camshaft sensor, Crankshaft sensor, timing belt, battery and ignitors. The car is joking with me... Am I missing something? I dont get any computer warning signals.... I am strugling with it for 3 years, so any advice is appreciated, Thanks for reading BrokenWheel. tomminajar 12-02-2004, 09:59 PM What are igniters (spark plus??) Most likely ... Your fuel injectors are leaking and dumping raw gas into the intake manifold and flooding your engine. Try holding the gas pedal to the floor (clear flood mode - shuts off fuel pump) next time and see if it starts better. Major $$ to fix unless you do it, fairly simple - -Good Luck BrokenWheel 12-05-2004, 02:16 PM Thanks for reply, I'll check it. Automotive Network, Inc., Copyright ©2012
