528E runs richbillerica 12-02-2004, 01:06 AM I have an "86 528E that runs very rich. I had it into a shop for a tune up and it was better for a bit. It starts hard and runs rough. It will push some blue smoke consistant with running rich. Any suggestion on what to check and in what order I should look? TNX RR KC Ron Carter 12-02-2004, 01:33 AM If it starts OK, and that is a big deal. Then I would suspect the o2 sensor output. As the sensor gets weaker it will provide less voltage. o2 sensor readings. You can check it on your volt ohm meter. Use a VOM on pin 24 on the ECU or the black lead on the O2 sensor. .6 volts is dang rich .3 volts is dang lean. http://www.kemparts.com/TechTalk/tt07.asp Later, jeffreyb4me 12-02-2004, 07:48 AM A few other possibilities might be: 1] Poor or broken connection @ the coolant temp. switch [NTC] located on the thermostat housing. If your car received the "Summer Campaign of 1987 it had a 480 ohm resistor added at the connector and they can break causing an open circuit. 2] The M20's also had a "35 degree switch" added to the throttle heater hose coming off the t-stat housing, these also fail, can safely be removed ALONG with the harness to the NTC that was installed during the "Campaign". Both these will cause a rich condition. 3] As "KC Ron Carter" mentioned, the BEST way to diagnose your problem as electrical is a complete pin test at the DME Control Unit, no guess work needed then. 4] Also check for a sticking fuel pressure regulator though it's a little late in the fuel blend season for this to happen, they still fail. Automotive Network, Inc., Copyright ©2012
