Plugged Heater Core?CSR44 12-01-2004, 08:50 AM I have read the threads and I was wondering if this is also a plugged heater core: Temp level good, coolant level normal, new t-stat, very faint warm air coming out. If I rev the motor, I can hear the heater core "girgle" and the air gets hot, soon as I back the throttle back down to idle, cold air? I think I will try the Superflush kit for the heck of it. Thanks, CSR tom3 12-01-2004, 10:17 AM Sure sounds like air in the system to me. Be sure to actually take off the radiator cap and check level. CSR44 12-01-2004, 01:02 PM Yes, I made sure both levels were good. I also felt the hoses and they feel the same temp. I am going to try taking the hose of the core and back flush with h20 while I have em off. I thought the core was air locked so I parked the nose on a steep hill and took the cap off, no results? Fractured1 12-01-2004, 03:50 PM still sounds like you might be moving some air around..and for the cost I would replace the radiator cap... Automotive Network, Inc., Copyright ©2012
