parts from 97 ex d16 and 92-95 b16aroguecivic97 12-01-2004, 01:07 AM this is a re-post, just wanted to make sure i've got all my bases covered. ok, here's what i've got (prices are somewhat negotiable) parts from d16y8 97 civic ex: short shifter (chrome)-$40 centerforce dual friction performance clutch (hardly used)(retails on nopi for over 600)-$400 rear motor mount bracket-$50 stock headers w/heat shield-$80 also have the stock computer for the d16y8-make an offer parts from 92-95 b16a sirII: stock motor mounts-$40 each rear motor mount bracket-$50 power steering pump-$70 a/c bracket-$50 timing belt tensioner (brand new from honda, never opened)-$60 I also have a set of 10" subs (kicker comps) 8ohm in a box as well as a rockford fosgate 250a2 (still have original box and birth certificate) amp is rated at 406 total watts if the subs are run in parallel and the amp is bridged... these subs should hit 136.8 db (I took third place in an spl competition with these subs) whole package deal for this setup-$200 if you have any questions you can email me at roguecivic97@sbcglobal.net or i can usually be found on aim with the same name Automotive Network, Inc., Copyright ©2012
