Evo MR vs. M3 vs. STiSkylineBNR34 11-30-2004, 01:51 PM Can anyone tell me what the weight, quarter mile, and 0-60 figures are on these cars? as well as some opinions on what the better buy is? Thanks!!! Mitsubishi Evo MR BMW E46 M3 Subaru WRX STi Automatic 51 11-30-2004, 07:07 PM if you go to www.mitsubishimotors.com and click on the evo section you can get side by side stats/comparison of all those cars. kman10587 11-30-2004, 07:09 PM www.edmunds.com will have weight, power, and all that stuff. As for 0-60 and quarter mile times, you're gonna get a very wide range. I would guess that the STi is the fastest in both of those sections, but the Evolution MR is certainly a better overall performer. The M3 is awesome, but it's a lot more expensive than the other two. It has a nice interior and brand cachet, though. G35turbo 12-05-2004, 01:14 AM go to www.car-videos.com and u can find the 0 to 60 and the 1/4 on the Sti and the M3, but the EVO MR based on Road and Track. 1/4 is 12.9 0 to 60 is 4.3. Curb weight: 3085 lb Test weight: 3280 lb Engine Type: iron block & alum. heads, turbocharged inline-4 Valvetrain: dohc 4-valve/cyl Disp./Bore x stroke: 1997 cc/85.0 x 88.0 mm Compression ratio: 8.8:1 Horsepower (SAE): 280 bhp @ 6500 rpm Torque: 295 lb-ft @ 3500 rpm Redline: 7000 rpm Chassis & Engine Layout: front engine/awd Brakes, front discs/calipers: 14.0-in. vented discs/4-piston fixed Brakes, rear discs/calipers: 12.0-in. vented discs/2-piston fixed Braking aids: vacuum, ABS Braking aids: vacuum, ABS Tires: Yokohama Advan, 235/45ZR-17 Steering: rack & pinion, pwr asst Turns L-to-L, turn dia.: 2.1, 38.7 ft Suspension, front: MacPherson struts, coil springs, tube shocks anti-roll bar Suspension, rear: multilink w/forged alum. links, coil springs, tube shocks, anti-roll bar Dimensions Curb weight: 3085 lb Test weight: 3280 lb Weight dist, f/r, %: 60/40 Length: 176.8 in. Width: 69.7 in. Height: 57.1 in. Wheelbase: 103.3 in. Track, f/r: 59.6 in./59.6 in. Chassis & Engine Transmission: 6-speed manual Gear ratios: 2.91/ 1.94/ 1.43/ 1.10/ 0.87/ 0.69 Speed in gears: 43/ 63/ 86/ 112/ 112*/ 112* Final drive ratio: 4.58:1 0-60 mph: 4.3 sec 0-1320 ft (1/4): 12.9 sec @ 107.6 mph Braking 60, 80 mph: 117 ft, 195 ft 200-ft skid lat. accel: 0.98g w/mild understeer 700-ft slalom speed: 70.8 mph w/mild understeer *Electronically limited Modifications Active Center Differential (ACD), upgrade turbocharger, 6-speed manual gearbox, Bilstein shocks, upgrade Yokohama Advan tires, BBS alloy wheels, carbon-fiber rear wing, vortex generator, exhaust tip Here is the link to road and track magazine http://www.roadandtrack.com/article.asp?section_id=39&article_id=1402&page_number=3&preview= I drive a 97 vr4 and when i went to the dealer ship last week they had one of the MRS the dealer ship had a $3500 mark up on the car. From 36k to high 39k. I think if you want just performance go with the EVO MR and a lot cheaper. STIguy 01-06-2005, 02:26 AM I dont know about the Evo MR but if your talking about the us version it should be about the same as the gsr 0-60 in 5.0 - 1/4 mile in 13.6. Sti 0-60 in 4.9 - 1/4 mile in 13.2 E46 M3 0-60 in 4.7 - 1/4 mile in 13.2 Master Hiko 01-09-2005, 03:46 PM dumb question, M3. now dont ever ask that again. FikseGTS 01-10-2005, 10:41 PM here are a bunch of them compared.... M3 vs Evo vs Sti (http://www.dragtimes.com/compare2.php?make1=34&model1=526&op1=%3E%3D&year1=2002&make2=42&model2=636&op2=%3E%3D&year2=2002&make3=5&model3=110&op3=%3E%3D&year3=2002&make4=&op4=%3D&year4=0&submitButtonName=Compare%21) . Turbo Meg 01-11-2005, 01:49 AM I can tell you the 0-60 on the 2005 Evolution VII MR is 4.59 seconds. The fastest Evolution model for 2005 is the RS, its also is the least expensive $28,500 plus dealer mark-up. The car is power delete no power windows locks no radio or sound deadning material no ABS. The best part about the car in my opinion is it also has no rear wing. The RS does 0-60 in 4.4 seconds due to weight reduction. Not sure on the rest of the performance numbers. I had to sign a waver from Mitsubishi Motors stating I understood the performance capabilities of the car and would not hold them resposible if in an accident. I live in Mass,and bought the car in N.H last week. Automotive Network, Inc., Copyright ©2012
