95 Jimmy vaccum leak ????
burkey41
11-29-2004, 01:27 PM
Hey, I have a 95 Jimmy 4.3 Vortec and was having multiple problems until i changed the cpi now i just have one. Before changing the cpi i had terrible gas mileage, rotten smell from exhaust and SES light, and also while driving at a constant 60 the engine will rev up and down. TACH will bounce from 1700-2000 rpm. After i found a leaky cpi and fuel lines i replaced them and all problems but engine rev were fixed. While putting the hoses on the back of the plenum i followed the smaller of the two back to a T and found that one of the hoses was not attached to anything and will suck air. I however cant for the life of me figure out where it leads or goes. Its only about ten inches long so it would seem like it shouldn't be to hard to locate. Any help would be appreciated with locating where that line goes or with other ideas that are causing the non constant engine speed. Thanks
Me123
11-29-2004, 02:51 PM
Check if the 4x4 and Cruise are working.
BlazerLT
11-30-2004, 01:16 AM
Can you take a picture of this?
burkey41
12-01-2004, 10:54 AM
yeah I'll take a picture so maybe you'll have a better idea of where everylthing is i am talking about.
BlazerLT
12-01-2004, 07:05 PM
kewl, then I will pinpoint and send you to exactly what you should connect it to.
burkey41
12-04-2004, 12:30 PM
Hey i took that pic but i couldn't get it in my post but it is in my gallery if you want to take a look at it for me. Let me know if this works or if i need to get the pic into a post.
BlazerLT
12-04-2004, 03:24 PM
Ah, perfect, that is what I needed, that is definitely a vacuum leak.
That hose attaches to the back side of that round black vacuum ball you see there.
There is a nipple there you push the hose onto.
burkey41
12-06-2004, 11:45 AM
THanks that was a easy, kind of embrassed i never looked up. That took care of the SES light being on but it still chugs and the Tach still bounces. Any ideas and thanks for all the help already.
BlazerLT
12-06-2004, 03:56 PM
Reset the computer by pulling the negative battery cable for 10 minutes to reset everything.
burkey41
12-06-2004, 04:03 PM
I noticed today because it was raining that underneath my car i have a slick where it appears i have feul leaking. It appears to be towards the front of the engine but who knows once things start running down hoses or other lines. Are there fuel lines around there that could have gotten damaged.
BlazerLT
12-06-2004, 04:07 PM
I would check the CPI and the nut kit again.
Also, smell your oil and see if you smell fuel or it is thinned out a lot.
rlith
12-07-2004, 07:56 AM
I truly hope he didn't cross thread the fuel lines when he put in the nut kit.
BlazerLT
12-07-2004, 11:58 AM
Pretty hard to. The nut kit is pretty stiff and is preformed to fix one way.
rlith
12-07-2004, 01:04 PM
you can easily cross thread those things at the line...
