Need Help On installing LD monitorhojai 02-27-2002, 10:52 PM Hi, I own a 99 g20t, and I'm going to install a lcd monitor,(not the expensive $1000 dvd decks), just the monitor. I want the sounds to come out from the car speaker instead of the little monitor. And my question is, is there any input for the monitor in the stock BOSE cd deck, or do I need one of those FM modulator. And does the FM modulator even work on the bose system? Because it seems (from the message boards) the BOSE system is different from all the after market system. Is the amp involves in this installation?? Please help me if anyone know what to do cliffud 02-27-2002, 11:58 PM Originally posted by hojai Hi, I own a 99 g20t, and I'm going to install a lcd monitor,(not the expensive $1000 dvd decks), just the monitor. I want the sounds to come out from the car speaker instead of the little monitor. And my question is, is there any input for the monitor in the stock BOSE cd deck, or do I need one of those FM modulator. And does the FM modulator even work on the bose system? Because it seems (from the message boards) the BOSE system is different from all the after market system. Is the amp involves in this installation?? Please help me if anyone know what to do FM Modulated= you hook up a unit that broadcasts a radio frequency and you tune your car radio to that frequency and it comes in on your car stereo. so... you don't have to worry about wiring into your bose system... it's WAAAAAAAAAAAAAY simple. c. P11GT 02-28-2002, 08:36 PM yep, theres lots of aftermarket cd changer that use FM, and theyre just plug, tune in and play:D no worries here. ctrainor54 03-23-2002, 01:28 AM hey, unless the p11's dont use teh legacy antennas (which im pretty sure they do) you will most likely have to run to your local best buy or other electronics store to pick up a 10 dollar antenna harness that basically takes the special nissan adapter and converts it to a universal plug, because RF adapters plug in using a standard antenna pin, and teh stock legacy plug has 2 pins in it. the clip is 11 bucks and is in the install bay, not the main store. just figured i would give you a heads up. Chris Automotive Network, Inc., Copyright ©2012
