timming chain
jtfrog
11-29-2004, 11:35 AM
On a 95 sl2 does the chain have a tentioner or just guides. My ticking noise is getting louder
sierrap615
11-29-2004, 10:57 PM
it has both:
http://www.saturnfans.com/photos/showphoto.php/photo/15049/
http://www.saturnfans.com/photos/showphoto.php/photo/15048/
shamefoot
12-07-2004, 01:42 AM
the top guide on my saturn 93 sl2 failed made a loud ticking noise -- baiscally it has a hard polymer between the metal of the guide and the chain the plastic shattered i had fun finding the pieces -- any way the plastic was gone and the chain was rubbing straight on the metal was able to fix that just by removing the valve cover and removing two bolts -- the majority of the plastic ended up in the valve chamber itself I'm sure i didn't get all of it out but oh well
sierrap615
12-08-2004, 12:26 AM
thats half of the reason i'm rebuilding, i'm going to tear the entire block apart, and scrub it clean
lwrdcav
12-08-2004, 06:20 PM
So you can tell when you need a new timing chain because theres a clicking noise? SH*T haha...90k miles....guess its time for a new one. Anyone have instructions on replacing this? thanks
sierrap615
12-09-2004, 12:54 AM
you can take the front cover off and inspect it, but with that much work you could just replace it. if the oil gets dirty/dark fast(in my case 700 miles) it is also a good sign of bad news.
very simplifyed how to:
support engine with hoist
remove engine mounts, belt, crank pulley
loosen exhaust downpipe
remove oil pan, valve cover, front cover
replace all timing components
that is a very basic how-to from memory, if you plan on doing it, i suggest getting a repair manual like Haynes or chiltons or such(i have and use both)
