left turn growling noiseghug 11-29-2004, 10:23 AM My 2001 Saturn SL1 makes a growling/buzzing noise when making a left turn above 10 mph. Has anyone experienced this? Kurtdg19 11-29-2004, 03:21 PM You might have a worn wheel bearing in your right front wheel. sierrap615 11-29-2004, 11:46 PM i'll second that Zgringo 11-30-2004, 12:02 AM The voting has been in favor of a front wheel bearing and seconded, any oppose? then I say look at the wheel bearing for problems. Albert mrrob 11-30-2004, 12:23 AM How bout a bad Cv Joint?, does it only happen when you make a left hand turn or does it happen, when the car reaches speeds above 10km? If your getting a constant (HUMMMMMMM) as you pick up speed, it's probably a Wheel Bearing, if it only happens when you turn left and it growls or clicks, it's probably a CV joint. Good Luck Mr.Rob Lic Mech Auto/Truck/Trailer Ect....! ghug 11-30-2004, 09:35 AM How bout a bad Cv Joint?, does it only happen when you make a left hand turn or does it happen, when the car reaches speeds above 10km? If your getting a constant (HUMMMMMMM) as you pick up speed, it's probably a Wheel Bearing, if it only happens when you turn left and it growls or clicks, it's probably a CV joint. Good Luck Mr.Rob Lic Mech Auto/Truck/Trailer Ect....! It only happens when making a left turn. It begins as soon as turn pressure is applied to steering wheel and stops as soon as turn is completed. I first suspected the power steering but no noise is detected on turns under 10mph. No clicking noise can be detected. Ghug 383PhoenixAm 12-01-2004, 03:13 PM As a rule, growling is mostly used to describe problems with bearings. Unless you can describe it as something else, that'd be the first place you should look. ghug 12-07-2004, 08:27 PM I replaced the right front wheel bearing and the noise stopped!! Thanks for the input! Gary Kurtdg19 12-08-2004, 12:09 AM I replaced the right front wheel bearing and the noise stopped!! Thanks for the input! Gary Glad to hear that. Hope everything else runs good for a while. If not, there are a lot of knowledgable people here (much more than I am) that are more than willing to help anybody in need. Just think of it as free help, until we all conspire a way to charge everyone....... :evillol: sierrap615 12-08-2004, 01:19 AM yea, feel free to drop in at the saturn section. most of my post are there Automotive Network, Inc., Copyright ©2012
