power windowwismo 11-29-2004, 09:09 AM Hi I have a 99 suburban with a power window (drivers side) that works intermitantly it gets to where it doesnt work then i take off door panel and tap the motor lighty and then it works again. Are these servicable or do i just need to replace it.I hate to spend the money if i can clean it or replace brushes or something.Thanks.. Larry Derouin 11-29-2004, 03:11 PM Hi I have a 99 suburban with a power window (drivers side) that works intermitantly it gets to where it doesnt work then i take off door panel and tap the motor lighty and then it works again. Are these servicable or do i just need to replace it.I hate to spend the money if i can clean it or replace brushes or something.Thanks.. http://www.1aauto.com/1A/WindowMotors/ChevyTruck/Suburban If you have an intermittent and have to tap on the motor, then more often than not the brushes are worn beyond service life. The motorsw are not serviceable except in a shop. These motor units are built better than the factory unit and carry a lifetime warranty.....which the dealer parts usually don't have. Larry wismo 11-29-2004, 04:01 PM great link but i dont see the one need i need left front drivers side . or did i miss it? thanks also does anyone know if i need to remove the window to replace this thanks all Larry Derouin 11-29-2004, 05:19 PM It's one of the two there listed as 92-99 window motors. Call them up and ask them which one to use. And no you can leave the window up. Just put a small wooden wedge in the bottom of the window to hold it up. wismo 11-29-2004, 05:59 PM Great thank you...It much appreciated Automotive Network, Inc., Copyright ©2012
