4hi dash button not working on 97 JimmyJimba61 11-28-2004, 12:17 PM The 4hi dash button on my 97 Jimmy doesn't engage the 4x4 transaxle. Nothing happens, no sound, no nothing. Is this a simple fix or should I take it to the dealer? (The 4Lo works fine.) BlazerLT 11-28-2004, 01:00 PM The Electronic Transfer case Case Encoder motor is defective. Swap a working one in from a wreck in a pick and pull and you should be set. brett85p 11-28-2004, 05:53 PM I have the same problem on my 98 Jimmy, do you have to pull the front axle out to change the ecoder motor? BlazerLT 11-28-2004, 07:04 PM from what I have heard and seen, it should be a straight pull and replace. I can't personally tell you from my actions seeing I have never done it on my particular truck. troubles789 11-28-2004, 08:40 PM Bolt on and plug connectors. Easy fix. $100 used at junk yards. $50-$100 on ebay. $400 at dealer. goldwing109 12-01-2004, 08:23 PM I had the same problem. Someone on this forum suggested disconnecting the battery for about a half hour. It worked for me. brett85p 12-02-2004, 09:02 PM Thanks for the tip, just did this now working fine. BlazerLT 12-02-2004, 09:53 PM Keep an eye on it, the condition does come back after a while. Automotive Network, Inc., Copyright ©2012
