Power steering pressure switchRowdysrides 11-28-2004, 08:49 AM Well I should have known, after all the work we did to our 96 3.8 this year (water pump, tie rod, head gasket replacement, etc) it comes up with a NEW problem yesterday. Whenever we would pull into a parking spot it would stall....only on a full complete turn. So did some research on Alldata and it seems it may be the 'Power Steering Pressure Switch', anyone been 'lucky' enough to have to change one of those?? I know it's located on the rack. Any suggestions or helpful tips would be appreciated. Thanks windstar4family 11-29-2004, 12:09 AM If my memory serves me correctly the ps pressure switch is on the left side of the steering rack, just below the brake booster/master cylinder. It is located on one of the ps lines going into the rack. You can see it through the drivers fender well if you take the lf tire off and peer through past the inner fenderwell. Hope this helps. Automotive Network, Inc., Copyright ©2012
