Performance chip will it work?
.-=BlueCivic420=-.
02-27-2002, 05:37 PM
I was wondering if I can put a performance chip in my 95 Honda civic dx automatic. I saw a few on ebay I read the info on them and it said they were unsure if it would work. any help would be appreciated thank you.:smoka:
90CRXZCSi
02-27-2002, 08:07 PM
I really dont think it will do much for a DX(no offense). it would be better for a B16A or something most likely.
.-=BlueCivic420=-.
02-28-2002, 03:27 PM
So basically ur trying to say is it won't work at all ? or what? It must do something... Well thanks again:smoka:
Si2000 Vtec
02-28-2002, 03:37 PM
To save the confusion and put it simply... don't waste your money. If I were you, I'd save your money for either FI or some quality bolt-ons.
SRHguru
02-28-2002, 03:56 PM
http://www.automotiveforums.com/vbulletin/t32412.html
Here is a link to a post talking about chips and stuff, because I also was curious.
Brice
02-28-2002, 06:11 PM
I agree man. I wouldn't waste my money on a chip or new ecu unless it's a car worth spending it on, and when I say "a car worth spending it on", I mean really high output all motor cars or FI cars. Other than that, I wouldn't waste my money on it until you really need it.
ric
02-28-2002, 10:38 PM
well you might as well not waste your money on a performance chip for your honda. just buy a bag of doritos and smash it into the ecu cause it is generally gonna have the same effect (and you would still be using a chip, sorta)......nothing. if you have a chip fetish like some do i suggest a nice 1.8t or a scooby, those should wet your chip craving palate.
madmax623
06-06-2004, 03:18 AM
Idk man. I put a chip in my Ex and it made all the difference in the world. changes the powerband totally. And for what 20 bucks off Ebay??? go for it.
kicker1_solo
06-06-2004, 05:41 AM
wow, you brought back an old thread from almost 2 1/2 fuckin' years ago man. :rolleyes:
jameskersten
06-06-2004, 10:16 AM
i wouldnt buy any "chip" off ebay. the problem with most of these chips is they are a generic chip, meaning they make 1000's of them all the same. you cant tell me everyone;s motor is the exact same, a good chip is programmed to your motor. ie. fuel/ignition curve based on your mods etc.. only good thing about some of these chips is they play with your vtec X over, which is bad sometimes too. i bought one of these for my b18c1 (skunk2 genaric ecu) and i can tell you only thing it was good for was a no fuel cut and higher red line, again that can be bad for some people. it dumped so much fuel it was retarded, i got worst gas milage then i had ever seen by a civic. a good tuner knows leaner is hp. i mean that to a point so dont think i mean run at 15psi on your fpr. when you tune a car you lean the motor out until you get knock, that is gonna be your peak hp, then give a bit more gas to eliminate the knock. these chips dump fuel therefore you get poor milage plus poor performance.
i guess these are all opinions but i cant deny the chip was terrible on gas and it wouldnt give enough performance to justify the milage.
madmax623
06-06-2004, 11:34 AM
hahaha I was wondering what would happen if I posted.
kicker1_solo
06-06-2004, 06:17 PM
people would think you're a dumbshit, way to go, mission accomplished. :)
Automotive Network, Inc., Copyright ©2024
