Minor frontend damagesbdivemaster 11-27-2004, 03:58 PM Hello-- 1995 Escort LX Wagon Dark Forest Green Does anyone know of a source for front end diagrams/schematics? I have the Haynes guide for this car, but the body drawings are just not that detailed and the photos are too detailed. Had a slight front end mishap and need to replace some parts. Just want to make sure I have got everything covered. Maybe someone knows if the headlamps are a whole assembly or if the plastic bracket that holds the actual lamp (it is also what the plastic grill snaps into) can be found separately. Any help would be great, thanks. bigrod118 11-28-2004, 07:14 PM no the headlight assembly is attached to that black plastic bracket that holds the grille too, if you still have your old parts hold them up to where they should be and you should notice there are 5 bolts that go thru that plastic bracket that hold the lights onto the car. two bolts one one side, two on the other, and one on top. bigrod118 11-29-2004, 04:52 PM no that black plastic peice, the bracket, is part of the headlight assembly, it doesnt come off, you cant just buy the headlight nor can you just buy that bracket, they are both one single piece, those together are the headlight assembly. so if your just looking to replace that black plastic peice so you can snap your grille into it, you have to buy new headlight assemblys, or do what I did when mine got fucked up......zip-ties. Automotive Network, Inc., Copyright ©2012
