1992 s15 jimmy and abssnake911 11-27-2004, 12:54 AM I have a 1992 gmc jimmy that I just completely restored. Everything seems to be working fine on it except lately my abs has been kicking in when I apply the brakes (but the wheels are not locked up) anywhere between 25 and 15 mph. This problem only started happening after I had the bearing replaced on the front right and the abs light is on which coincidentally, the truck seems to dive to the right as well while braking. The abs is working when the wheels get locked up. I would appreciate any feedback. Thanks in advance and great forum, long time reader. j rlith 11-27-2004, 10:34 AM When you replaced the hubs, did you replace the dust shields? The abs sensors are integrated into them, they could be worn and not working properly anymore. snake911 11-27-2004, 08:41 PM Ahhhhh, they were not replaced and I will do that first thing tomorrow. Thanks a lot, much appreciated. j rlith 11-28-2004, 09:32 AM Not a probl, let us know how it turns out. I ended up switching to 2001 front brake system (everything is the same style up to 97) 98 to current integrates the ABS sensors into the hub itself. Makes it a bit easier...:) snake911 11-28-2004, 11:31 PM searched all over for parts today....most places said i have to go directly to chevy, is this true for getting the dust shields and abs sensors? how much should something like this run? thanks. rlith 11-29-2004, 07:30 AM they are available at advance autoparts They are about 80 bux each snake911 11-29-2004, 01:16 PM they seemed to think it was the abs module since my abs is still working, albeit at the wrong time (while braking in between 30 and 15 mph and wheels are not locked). I guess if it were the sensor located on the dust shield, the module would completely disable abs and therefore, since my abs is still working he says it's probably the module. Of course this problem only started after i had work done on the front end (bearings) so I thought it was definately the sensor. Does this make sense before i fork out all this money? rlith 11-29-2004, 05:48 PM I would still lean more towards the sensor. I've rarely heard of the ABS module itself going bad. Very few and far between stories. snake911 11-29-2004, 06:15 PM i appreciate your help on this. i know absolutely nothing about abs. is it true though that if that sensor was bad, the module would shut abs completely off and thus abs wouldn't be working at all? alternatively can i just disconnect the module until i get this resolved?? rlith 11-29-2004, 06:44 PM You can disconnect the module (do it at the positive cable, you will see a quick connect there) But it will set the ABS light on the dash. No, i a sensor is being erratic it won't always set the light. pjmman 04-18-2005, 08:43 AM I just disconnected the abs ..the light will stay on but no more problems Automotive Network, Inc., Copyright ©2012
