P0133 02 Sensor and P1406 Emissions Controller Codes
jtquad
11-26-2004, 01:00 PM
Does anyone know what part i need to replace to clear these codes? I Have an ODBII Scanner and this is what keeps kicking up. It is on a 1996 Saturn SL2. Thanks ahead of time - Joe
sierrap615
11-26-2004, 08:20 PM
P0133 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 1)
the front O2 sensor needs replaced, most likey it is covered in carbon build-up
for the P1406, i'm not sure, i can't find the exact code, but take care of P0133 first and see if it comes back.
jtquad
11-26-2004, 09:27 PM
Excellant, Thank you very much, Ill let you know how it turns out - Joe
sierrap615
11-26-2004, 11:11 PM
DTC P1406 EGR Valve Pintle Position Circuit
i don't know exactly what this code means, most EGR problems can be solved with a good cleaning.
take the EGR off, clean it with sensor safe carb and choke cleaner, spray a little into the passages in the head to, replace the gasket also.
jtquad
11-27-2004, 08:31 AM
Thank you both so much, Ill see if this works on monday and let everyone know - JT
