1988 Honda Accord LX
bigjimjack
11-24-2004, 08:44 AM
I have a 1988 Accord LX with a blown #1 cylinder. So, I looking to drop a V-Tech in there. I need suggestions.
civickiller
11-24-2004, 01:38 PM
h22
ridestreet84
11-24-2004, 02:33 PM
i agree with the h22 not know how well the swap will go but that or an older honda prelude b20 i think not sure if thats the correct code
F23A4Racer750IL
11-25-2004, 03:29 PM
first off there is no direct or easy swap for a 3rd gen accord. it will be alot harder to swap a different engine in this car than say 4th and 5th gen accords. here are some options u can get rid of ur carburated engine in favor of a A20A3 fuel injected engine, or the F22A6 from a 4th gen accord (SE,EX) or the F22B1 engine for a 5th gen accord Ex.
110hp/114tq A20A3
140hp and 142tq SOHC 16v F22A6
145hp and 147tq SOHC 16v F22B1
veedubxlr8r
01-24-2005, 02:27 PM
info on F22 swap, looks like it's NOT worth it
http://www.3geez.com/showthread.php?t=39403&highlight=f22
http://www.3geez.com/showthread.php?t=39887&highlight=f22
goto www.3geez.com for 3rd gen accord performance
lots of info on modding the stock A20 engines, many guys big on upgrading carbed accord engines
engines you may want to consider are older the B16 and B18A1
preludepower.com has some info on this (2nd generation prelude info, similar A20 engines as 3rd Gen accords)
big bad mohawk guy
01-27-2005, 09:02 AM
h22 and a t3/t4 turbo or at least a t3
veedubxlr8r
01-28-2005, 05:34 AM
don't waste your time with an H22 (same mounts as F22) engine swap
yeah, it's an awesome engine, if you'd like to have custom engine mounts, custom axles, shifter linkages, and a hell of alot of hardwiring (and tons of little things here and there)
a B16 can be dropped in, 160 hp... over the factory 110 hp A20a3 that you car most likely has
that's a 45% increase in hp (torque numbers not available)
that's like a decent turbo setup on an A20
and there are many turbo kits and manifolds available, for future modding
and no offense, big bad mohawk guy, but i'm proud you found out how to redline in second gear (my cavalier wagon hits around 85 in second, btw, and i doubt it's faster than your car), that's quite the pointless thing to say about your car
and, people, don't "gut" your cat by shoving a broomstick up the exhaust
this gives the exhaust a blattey RICER sound, and not only illegalizes and ruins your exhaust, but is pretty retarded to even consider
if you don't want a cat, go spend $20 and put in a straight pipe (not what i recommend), or get a CATCO cat (not the "glasspack" shaped so-called "reduced" cats, they're not cats, they're resonaters)
just for all your information
