Check Engine Light On & Wont StartNOBRA14 11-23-2004, 06:42 PM 91 Accord was running fine, went to start check engine light stays on, motor turns over but wont start. Disconnected battery, removed ecm fuse 1/2 hr. Placed jumper wire to get engine code but check engine stays on no matter what i do. will not go off to get code.. AccordCodger 11-23-2004, 07:51 PM Might need a tow to somewhere that can pull your code (Autozone, for example). Without knowing that ----- it could be anything (well, ALMOST - I guess a flat tire could be ruled out as the cause :)) NOBRA14 11-23-2004, 08:09 PM Even though the check engine light when jumped ,stays lite there would still be a code in the ecm that can be read with a code reader? AccordCodger 11-23-2004, 08:32 PM Yeah. The ECM stores some number of previous codes (I don't know how many) not just the current one. mpumas 11-24-2004, 02:23 AM You can determine the code by installing the jumper in the service connector located under the dash to the right of the glove box. It is a 2 pin connector that when jumpered turns the engine check light into a code light. Read the codes and look in the book. A long on light is a 10 and short light on is 0-9. Automotive Network, Inc., Copyright ©2012
