2001 just shut off -no power
EWalrath
11-23-2004, 10:37 AM
I was driving a few days ago and without warning the truck just shut off and now its completly dead . the battery is fine but no lights or anything. is this a computer problem?
tom3
11-23-2004, 12:08 PM
First thing I'd try is to shake the battery terminals/posts. Not uncommon for the factory Delco battery to have a post break off. Sounds crazy, but it happens more often than you'd think. Then try to pull on the mid sized power wires from the battery cables, they have fusible wire lengths in a different colored section of the wire and they can burn in two. The wire will stretch out if it is burned in two.
EWalrath
12-01-2004, 07:56 PM
Thanks but that wasnt it Ed
autohelper7
12-02-2004, 01:50 AM
did you take a test light and check all the fuses?
j.patelia
12-02-2004, 11:44 PM
Two words, check fuses. Since your truck shut down all of a sudden, check the fuses that are under the hood first. Sounds like you blew a large fuse. The other one is add some fuel. I actually had this problem where the truck shutdown, but in reality it was out of fuel even though it was showing a quarter tank!
EWalrath
12-22-2004, 04:37 PM
Thanks but its not the fuses
tom3
12-24-2004, 09:00 AM
I'd next suggest the ignition switch, on the steering column down under the dash. Might bang around on it some while you cycle the key and see if you get any response.
mike1224
01-24-2005, 10:06 AM
i was having same problem, cables were'nt connected well enough, when i eventually bumped a curb just right, no more power.
