Rx7 Faq
ac427cpe
11-23-2004, 03:13 AM
If you feel that you have something important that everyone in this particular section of the boards should know: post it here.
If a post is not a question and answer, it will be deleted. DO NOT respond to posts here, this thread is for information only.
Please designate the generation of car which each piece of information applies to, if it is for all, say ALL.
D3rELiC
11-23-2004, 09:36 AM
how a rotary engine works (http://www.howstuffworks.com/rotary-engine.htm)
looking for something ? click here (http://www.automotiveforums.com/vbulletin/search.php?)
FAQ thread, where you can ask for something
http://www.automotiveforums.com/vbulletin/showthread.php?t=312648&page=1&pp=20
ShortyDTP
11-23-2004, 10:12 AM
FC3S 86-89 Specs, and imformation. http://2ndgenrx7.freeservers.com/page1.html
fcdriver
11-23-2004, 12:21 PM
Common problems and ways to fix them.86-91 http://www.atlantarx7.com/secondgenfaqs.html
Different types of portings for a rotary. http://home.iprimus.com.au/bluey3/portsPage/ports.htm
A list of registered importers. http://www.nhtsa.dot.gov/cars/rules/import/web_RI_list07142004.html
Another importers site. http://www.japimportsusa.com/
Car comparisons will be better accepted here. http://www.automotiveforums.com/vbulletin/forumdisplay.php?f=666
89tracerman
11-24-2004, 10:53 PM
what to look for when buying an FC
http://fc3spro.com/TECH/h2b.html
FD Buyer's Guide
http://rx7.voodoobox.net/infofaq/bguide3g/bguide3g.html
How much Horsepower did the FC come with from the factory?
86-88 NA = 146 HP @ 6500 RPM w/ 138 Ft/lb @ 3500 RPM
86-88 Turbo = 182 @ 6500 RPM w/ 183 Ft/lb @ 3500 RPM
89-91 NA = 160 HP @ 7000 RPM w/ 140 Ft/lb @ 4000 RPM
89-91 Turbo = 200-202 @ 6500 RPM w/ 196 Ft/lb @ 3500 RPM
Infini IV = 215 @ 6500 RPM w/ 206 Ft/lb @ 3500 RPM
Will an FD motor fit in an FC?
The motor mounts are in different locations as well as other issues; however if you have enough time and money it can be done. It is generally cheaper and easier however to put in a 20B (typically around $10,000 installed) than it is an 13B-REW from a FD. http://fc3spro.com/TECH/SWAP/FD3S/rew.html
fcdriver
11-25-2004, 05:12 AM
A good FC3S N/A to turbo engine swap guide..http://www.rotaryresurrection.com/
Rebuilt rotary engines..http://www.rotaryresurrection.com/ ,
http://www.pineappleracing.com/
S4 to S5 intake swap..http://homepage.mac.com/carldavis/intake.html .
D3rELiC
12-01-2004, 02:41 AM
edited by ac427cpe; this is for information only, opinions go in other theads.
FB-FC stuff. mostly FB
http://members.ij.net/mrmazda/cfaqmenu.html#FCF
drftk1d
12-30-2004, 04:21 PM
what is premixing?
Pre-mix: mix motor oil and fuel so that they can be injected into the chambers at combustion time. It is advantageous because the rotary burns a little oil by design. You can remove the OMP to do this, but its not always necessary.
http://www.nopistons.com/forums/index.php?act=ST&f=65&t=14446
http://www.nopistons.com/forums/index.php?showtopic=44931
fcdriver
01-05-2005, 03:10 AM
Third generation RX-7 specs and production numbers http://www.turborx7.com/rx7specs.htm
D3rELiC
02-07-2005, 07:32 PM
link list, i'll put some order in all this when it will be completed
http://www.fc3spro.com
http://www.rx7club.com
http://www.mazspeed.com
http://www.fc3s.org
http://www.geocities.com/MotorCity/Speedway/3734/firstgen.html
http://www.geocities.com/MotorCity/Speedway/3734/secondgen.html
http://www.geocities.com/MotorCity/Speedway/3734/thirdgen.html
http://www.sa22c.org/
http://www.racingbeat.com
http://www.mazdatrix.com
http://www.iscracing.net/
http://www.ground-control.com/
http://www.2751engineering.com/blackfc.html
http://www.rx7.com
http://robrobinette.com/
http://www.rx7trix.com/store/customer/home.php
http://www.rotaryengineillustrated.com/
http://www.cpracing.ca/
http://www.clean-air.org/index.html
http://www.gforceengineering.net/
http://www.vintagerotaries.com/FORUM/
http://me.a-spec.ca - down
http://www.rotaryextreme.com/new.html
http://www.rx7specialties.com/
http://www.rx7canada.com/index.html
http://auto.howstuffworks.com/rotary-engine.htm
http://www.catenet.net/dyno.php
http://www.geocities.com/cd23c/dlidfis.html
http://www.aaroncake.net/
http://www.dmrh.com.au/jcspecs2.htm
http://members.aol.com/solomiata/Drivetrain.html
http://www.cochran-racing.com/FSM/index.html
http://slackerware.dynu.com/fsm/
http://208.62.166.66:82/guest/shop_manuals/
http://www.teamfc3s.org/main/factor...nual/1986_1988/
http://www.teamfc3s.org/main/factor...nual/1989_1991/
http://www.rx7.com/cgi-local/2ndgencalc.cgi
http://rx7.com/cgi-local/3rdgencalc.cgi
http://toy4two.home.mindspring.com/offset.html
http://www.16paws.com/rx7/index.html
http://www.mazdatrix.com/g1.htm
http://www.hitman.hm/13BHints.htm
http://www.newwave.net/~flanham/wlanham/
http://www.rx7s.com/
http://www.solarwinds.com/jdbooker/rx-7faq/
http://www.sevensonly.com/
http://home.mn.rr.com/linnihan/1600cc_seconday_injectors.htm
http://cp_www.tripod.com/rotary/pg03.htm#R26B
http://www.thedodgegarage.com/turbo_coolers.html
http://www.fd3s.net/index.html%3fsection=article,186
http://www.rx7turbo.com/index.htm
http://www.k2rd.com/haltech/drawings/rx7drawings.html
http://www.carfolio.com/specifications/models/?man=3808
http://search.yahoo.com/search?p=Hydrogen+Rotary&fr=FP-tab-web-t&toggle=1&ei=UTF-8
http://rx7.freeservers.com/
drftk1d
02-23-2005, 12:49 PM
Factory Service Manuals:
covers model years 1986 thru 1995.
drftk1d
04-19-2005, 01:53 AM
awsome FAQ on the FC3S 2nd gen rx7 (86-91)
http://www.car-forums.com/talk/showthread.php?t=10248
iougs
05-10-2005, 12:24 PM
Troubleshooting info for 86-88 rx-7 non-turbo:
The MAZDA RX-7 86-88 technical page (http://rx7.subbuteoclub.com)
iougs-
DropTop88RX7
08-17-2005, 08:23 AM
Another Great Site is:
http://www.iluvmyrx7.com
master-richie
10-22-2005, 02:42 PM
had an interesting problem come up on an '87se i bought for an engine swap.
the girl i bought the car from said her boyfriend tried to start the car one morning and it wouldn't. she brought it to mechanics and they couldn't figure it out. i cranked the car, the exhaust pulse was low so i figured mebbe the seals had blown. didn't matter the motor was coming out and i was putting in a fresh s4 street port engine. paid her $150.00 and went on my merry.
fast forward --> got my motor in and guess what, IT WOULDN'T START! checked vitals; spark, air and gas. gas to the injectors but no gas in the engine. pour some gas down the intake and it'd start right up. looks like a dead ECU right? NOPE!
the injectors we're getting power and the ECU was giving the correct ground pulse. what gives? power and ground = a complete circuit?! bad injectors, all 4? doubtful. i checked the schematic.
then i caught it *** condensor F-43 *** it's official name is Radio Noise Filter ($6.00 part). this sucker is a RF noise suppresor for injector noise. a capacitor directly connected to the power side of the fuel injectors. a little black square semiconductor mounted under the trailing ignitor with a single wire coming off it (F-43). when they go bad, they leak voltage from power to ground = short circuit. but this only happens when they cycle = cranking the car. so that's why i had power at the injectors when i checked, I WASN'T CRANKING THE CAR!
i disconnected the lead and cranked the car - VROOM!. swapped in another and i've been tearing up the roads ever since! ~Rich
jcsaleen
06-18-2007, 01:53 PM
www.FD3S.net ~ FD index site for a lot of problem solving and broken down by catagory.
