My revlimiter on my d16z6 kicks in al like 8200 ish, andway if you do want to go higher then that i highly recomned better valve springs, its about 300 for a set of 16 and then it will be safe to hit higher RMPs and not have to worry about a valve staying open and hitting a piston. to answer your question, youd need to get your ECU chippid or reprogramed, its like 200 and the advance you timing curves and all that...
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
