96 Aurora trannyboywetzel 11-21-2004, 10:52 PM I just installed new shift solenoids-one was broke from filter. Put all together,disconected the battery to reset service engine-it worked.My problem is when I start the car and put it in gear it is if I have no transmission.No 1st -drive,reverse nothing-yes I reconnected the linkage.Please Help!!! Tom shuffler 11-30-2004, 11:20 PM I just installed new shift solenoids-one was broke from filter. Put all together,disconected the battery to reset service engine-it worked.My problem is when I start the car and put it in gear it is if I have no transmission.No 1st -drive,reverse nothing-yes I reconnected the linkage.Please Help!!! Tom I replaced the A/B shift solenoids in my 95 aurora and the kit came with an L bracket necessary to hold the screen filter in place that's located btwn the 2 solenoids. If you don't install this L bracket the filter will blow out of position and cause the transmission not to shift properly. boywetzel 12-06-2004, 08:26 AM I did install the L bracket-when I installed the new solenoids both had same part number.Are the solenoids different? Thanks,Tom I replaced the A/B shift solenoids in my 95 aurora and the kit came with an L bracket necessary to hold the screen filter in place that's located btwn the 2 solenoids. If you don't install this L bracket the filter will blow out of position and cause the transmission not to shift properly. Automotive Network, Inc., Copyright ©2012
