service engine light
aurora13
11-21-2004, 06:16 PM
Hello I just got my 98 aurora back from a mechanic after doing the head gaskets, he said the only thing left to do is replace the cam sensor so I did and the engine light is still on. I runs rough at idle but it drives fine and the engine light is on. Is there anyway I can find out what code it is so I can fix it myself.
treeboy38
11-21-2004, 06:23 PM
Get the codes read at autozone.
zimaad
11-21-2004, 06:38 PM
Harbor Freight Tools has a generic code reader that will pull codes and is on sale now for like $40. It's not the best unit in the world...but it works. I got one and it pulled the codes I needed. Also....can you ASK hte mechanic. I assume they pulled the codes...so they should be able to tell you. Did they not reset them...or did they just go off again?
aurora13
11-21-2004, 07:00 PM
how do you reset the codes
aurora13
11-21-2004, 07:32 PM
I forgot to mention that the tachometer all of sudden when I was at a stop started going crazy, it was jumping from idle to 3k rpm's to 2k rpm's to 4k prm's and back up and down again, but the engine was not revving up it stayed at idle, anybody know what that is
zimaad
11-21-2004, 10:02 PM
you have to have a scan tool to reset the codes. The one I posted earlier will reset codes, but you can't just do it yourself w/o the equipment (unplugging the battery may..but not sure).
Hesam
11-26-2004, 01:39 AM
When I changed the oxygen-sensor in my Aurora and sensors turned out to be the wrong model #, check engine light came on, so it could be the wrong sensors mechanic put in your car.
aurora13
12-12-2004, 02:14 PM
hello my tach has been going nuts lately when i am driving or stopped it will all of sudden just jump up and down from 1k to 3k to 2.5k to 4k and so on, does anyone have any idea what it is
also I had my ses light come on and it was the cam psition sensor, I replaced it cleared the code and its back on now and the car is running very rough when at idle
any feedback would be greatly appreciated
thank you
