92 Passat erratic stalling/rough running
Google
Web AF
GreggKote
11-21-2004, 04:12 PM
I have a 92 Passat GL with the 2.0L DOHC four cylinder with 160K miles and a manual transmission. Since I purchased the car I have replaced the distributor cap and rotor, plug wires, main fuel pump, and the fuel filter. Here are the symptoms I am experiencing: on sunny and dry days, i can drive it without a problem (80 miles), i then shut it off in a parking lot and started it about half an hour later, it idled for a couple seconds then stalled out, I couldn't get it started after that. I checked the inside of my distributor cap for carbon tracking and it was clean, my high tension coil wire was good as well as my plug wires, i checked the electrical connection to my fuel pump and that was good. I turned the key to "run" position and i could hear the priming pump in the fuel tank run. I eventually got the engine started but it wouldn't run at less than 1500 rpms. So i started driving back home in third gear in order to keep the r's up. Whenever i came to a hill the engine would start to stumble. After 11 miles it stalled on me again and would not start, i had it towed the rest the way. When it came off the flatbed two hours later, it started up without a problem and ran fine. The next day was real humid and foggy, this time it would start and idle fine but whenever i put a load on the engine it would stall out or "diesel" until the rpm's came back up i also heard backfiring through the exhaust. Fuel pressure is good, the fuel metering arm that floats in the intake operates smoothly without catching although it does have approximately 1/8" of play at the bottom of its travel before it begins moving the fuel metering plunger. With the engine idling i sprayed the distributor cap, coil, and wires with a water bottle and it didn't effect it. I found a troubleshooting guide that told me to check the ignition coil, all tests passed except for the primary winding resistance test, it had high resistance but the problem doesn't act like a dysfunctional coil. Can anybody offer some insight to this problem?
spasticone
12-15-2004, 11:11 AM
I don't know if this will help your car, but I put an O2 sensor in my passat and it took care of stalling problems. I think we overlook the O2 a lot because the replacement is 140 bucks. Use an 89 mustang lx O2 sensor. Same sensor, dif plug. All you do is solder it in to your old plug.
Google
Web AF
