clock and tripometer go to zerotamteal 11-21-2004, 10:42 AM my @'96 Passat 1.8 has recently had the usual maf sensor problem which are now hopefully fixed after a clean but lately when starting in the morning the clock and tripometer go to zero . any ideas . boschmann 11-21-2004, 05:21 PM Evidentally they are loosing power in the start position, perhaps a sign the ignition switch is starting to have problems. tamteal 11-22-2004, 12:53 PM Evidentally they are loosing power in the start position, perhaps a sign the ignition switch is starting to have problems. Thanks Boschmann , any reccomendations ? boschmann 11-22-2004, 04:19 PM If the battery isn't so wak that it totally loses power when cranking then replacing the electrical part of the ignition switch is the next choice. It's somewhat complicated for a do-it-yourself job. tamteal 11-22-2004, 04:42 PM If the battery isn't so wak that it totally loses power when cranking then replacing the electrical part of the ignition switch is the next choice. It's somewhat complicated for a do-it-yourself job. Thank You ,that's really helpful . vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
