problems after blow upBUFFSTUD 11-20-2004, 09:30 PM I recently bought a car from my sister that she overheated and kept driving, well with a dohc aluminum head she warped it. so i have it now, i got it all tore down,machined and put bace together and im sure the timing is off, so i crank it over and fuel sprays out of the injectors, so i replaced the o-rings and now when i crank it the fuel cutoff light comes on. the switch is good and i also dont hear the pump kick on when i turn the keyon??? anything will help thanks oh yea its a 92 escort gt w/ 1.8 DOHC barretire 11-23-2004, 10:33 AM I recently bought a car from my sister that she overheated and kept driving, well with a dohc aluminum head she warped it. so i have it now, i got it all tore down,machined and put bace together and im sure the timing is off, so i crank it over and fuel sprays out of the injectors, so i replaced the o-rings and now when i crank it the fuel cutoff light comes on. the switch is good and i also dont hear the pump kick on when i turn the keyon??? anything will help thanks oh yea its a 92 escort gt w/ 1.8 DOHC check fuse under hood i believe BUFFSTUD 11-30-2004, 11:54 AM Checked fuses, and everything else in the world hoping maybe i set the timing wrong, anyone know which marks on cam pulleys to use???? thanks vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
