Transmission works then doesnt work
kcautoparts
11-20-2004, 01:36 AM
Can anyone help? I have a 1995 Jeep Grand Cherokee. When i drive it down the road it shifts smoothly, then when i slow down and make a turn or slow down to fast i hear a little grinding or rumble sound in the right front and then it slows itself down pretty quick like the trans is down shifting to a much lower gear. But it also feels like something is poping out in the right front. Then when i start over from a stop position it will do fine until i slow down to fast or if iam making a right turn again. Sometimes when i drive it and floor it it will slip out of gear then catches but wont shift out of 3rd gear unless i put it in nuetral and then put it back into drive then it will run fine. As iam driving it will slip out of gear and rev up and then it goes nowhere. So i slow down and take it easy then it will work up to 40 or 50 mph and then revs up again. Can anyone help please? Thanks... Brenda
xj31
11-20-2004, 11:37 AM
the first thing to do is check the fluid.if thats ok then you start thinking about internal trans problems.
