98 explorer heat/ac
streetrodd37
11-18-2004, 04:16 PM
I have an 98 ford explorer that only blows cold air on max ac setting, all other settings blow hot air. I am unable to adjust the air on either setting, it is either hot or cold. I have replaced a leaking heater control valve and also the tempature control switch. any ideas or suggestions on how to fix this problem is much appreciated. Thanks
billyb
11-18-2004, 06:29 PM
I had the same peoblem as have alot of other people.Its your blend door.If you go to www.ford-trucks.com it tells you how to fix it,or you can take it to a shop and pay 1000.000.Good luck!!
fordnut1206
01-31-2010, 09:48 PM
Go to heatertreater.net they sell the blend door fix for a lot less than going to the dealer. I know I had to do it on my Ford.
