no head lights on jeep 95merick376 11-17-2004, 06:40 PM there is no power to the head lights i checked the fuse and its good the marker lights work everything works but the head lights please help a_alyte 11-17-2004, 06:58 PM Maybe your bulbs blew, or maybe the headlight bulb electrical connector came loose? I would check these two things after checking the fuse! Cam7 11-18-2004, 06:19 AM Check to see if you have power to the Light Switch. If you do you have a bad switch. If you dont have power check the brights with the switch on buy holding the bright lever on. Check power to the Dimmer Switch. Automotive Network, Inc., Copyright ©2012
