New Noise Developed
a_alyte
11-16-2004, 08:59 PM
My Jeep developed a new noise today, which can only be heard within the speeds of 25-40 mph. It's not that loud & can only be heard with the radio off & the window down (I live in the city)!
I did notice that the sound would disappear when I turn the wheel to the right!
Any thoughts anyone?
ChadEbert
11-16-2004, 09:04 PM
Big vehicle, where's the noise coming from? At least a general idea would be good, and what kind of nose is it, a clunk, squeel, whine, etc.
a_alyte
11-16-2004, 09:36 PM
I have a '98 GC 4.0 I6 & the noise seems to be coming from the front. I believe its coming from somewhere under the vehicle or in the tire area. It does't sound like its coming from the engine & performance is the same.
The noise sounds like somethings rubbing...similar to a piece of tape stuck to a tire ( I did check for this)!
I also noticed a rubbing sound when moving in reverse with the wheel turned to the right!
dksob81
11-16-2004, 11:21 PM
check your front wheel wells, it seems that u might have soemthing rubbing on the tires. turn the wheel lock to lock as well and check for clearence around everything.
a_alyte
11-16-2004, 11:47 PM
It just might be my front bumper (hopefully).
I know there's not that much clearance between my tire & front bumper.
Maybe my tires are to big?...P235/75R 15 (no lift).
JDPascal
11-17-2004, 12:05 AM
shouldn't be the tire size thats the problem. I have the same size on mine (up country tho) and no problems. now if you had 31 x 10.5/15 you could have a rub when turning. Thats what mine had on it when I first test drove it and it rubbed like h e double toothpicks.
JD
a_alyte
11-17-2004, 12:25 PM
After driving slowly w/the door 1/2 open, I was able to hear the noise better & it's coming from my rear driver side wheel, not the front!
Everything looks OK from a glance, now I'm thinking it might be the brake?
JDPascal
11-17-2004, 01:06 PM
could be the disc brake with the caliper slides sticking, something on the pads, or the pads worn down to metal.
Or - it could be in the park brake inside the rotor. Some mud, dirt or even a piece of the lining broken off like happened on mine.
hopefully not a wheel bearing!!!
a_alyte
11-17-2004, 01:31 PM
Yeah, I hope its not a wheel bearing too!
I might try spraying brake cleaner 1st to see if it helps!
a_alyte
11-17-2004, 07:05 PM
The brake cleaner did not help!
I think I gave a wrong description of this noise, it sounds more like a squeal (not very noticable)! I thought it was my drive belt but its not. The faster I travel, the faster the noise seems to move as well!
Again, this noise develops once I reach about 25 mph.
dksob81
11-17-2004, 07:53 PM
well it sounds like a rear wheel bearing is shot.
jeeperphil
11-17-2004, 09:03 PM
My 95 caddy did this too. turned out to be warn brake warning tab on rear brake. new brakes fixed it. only did it at certain speeds just like yours.
a_alyte
11-21-2004, 06:31 PM
I finally pin pointed the noise & it was coming from a wire near the transfer case. The wires are protected by a plastic covering & it was hanging & making contact with my rear drive shaft (creating the noise). I used a zip tie to elevate the wire & that solved the problem!
Thanks for all the replies
