Questions regarding Air Compressor and Dual Battery Mod
rhombus
06-11-2001, 07:38 PM
I'm looking for some advice and options:
I want to add an air system and dual battery setup to my X.
For the short term I will be using it to air up after 4x4ing.
In the long term I will be adding an air locker and will need a compressor for it.
So here are my questions:
I was thinking about getting an air tank for the short term and then adding a compressor later (when I get the locker).
The thinking behind this is that the tank would be much faster than the compressor for filling up.
Does think make sense?
If so where are you guys keeping the tanks?
For the ARB locker what other compressors will work (I was thinking about getting a 100 duty cycle compressor for air tools down the road)?
For the dual battery I was thinking about the idea that has been going around about building a box where the spare tire is.
Is anyone else working one this?
Just trying to get some ideas.
xterrabull
06-11-2001, 08:35 PM
Warmonger has just such a system (probably he's the only one).
Go to the "Just what can I make my X do" thread under the "mods/exterior" section.
The thread should contain a link (towards the end of the thread) to Warmonger's homepage where he details his system.
I suspect many of your questions will be answered.
ScottG
06-11-2001, 08:43 PM
Unless you are using a really big tank, I don't think it would be much good without the compressor. The small tanks that fit under your hood would probably only fill up one tire. What is the advantage of dual batteries over one good battery like an Optima? It seems to me like one good battery and maybe a heavy duty alternator would be better than dual batteries. Just my opinion on the subject :)
Mobycat
06-11-2001, 09:12 PM
I assume when you say "tank" you mean a CO2 tank? I kept debating the same thing you are and finally went ahead and got the ARB compressor. It may not be as fast as a CO2 tank, but it never needs refilling and it's half the price of a CO2 tank (unless you build it yourself). Maybe down the road I'll get a tank, too.
Figure it this way - you get a CO2 tank (10 lbs). You fill up your tires and invariably someone else needs airing up, too. (I think T and Will can attest to this). Not sure how many times either has re-filled their tanks, but it's $7-10 US each time. Refill for an ARB - press of a button.
Synchro
06-11-2001, 10:28 PM
yes, a heavy duty alternator would be cool. when you find one that will fit the X, let us know. ;)
the reason to have dual batteries, is you put all your accessories on one battery (offroad lights, winch, air compressor) and the main operating systems on another (ignition, headlights, etc) so if you blow the battery with your winch or whatever you can still get start your truck and get home. you also isolate these things to keep them away from each other and fighting for juice.
rhombus
06-11-2001, 11:06 PM
Thanks for the replys.
I have seen Warmongers site but that is a more advanced system than I will end up with (not that I don't want it).
I think that I will go with a compressor (maybe not the ARB as it is not a 100% duty cycle). But then again it is nice and small.
What do you guys think about trying to put a battery where War has his air tanks (just build a little box for it). Just thinking about it now. Not even sure if one would fit.
Mobycat
06-12-2001, 09:09 AM
If you want a 100% Duty Cycle compressor, prepare to pay out the wazoo. Extreme Air has one - it's $400. It also gobbles up a LOT of amperage.
rhombus
06-12-2001, 09:36 AM
I agree that they are expensive but not out of line.
ARB $300 20% 17 AMP
Extreme Air $400 100% 35 AMP
Currie Air $490 100% 32 AMP
So it is about $100 to $150 more for a 100% DC compressor.
Not that crazy if this thing is going to last years.
The dual batteries should take care of the extra AMP draw.
ScottG
06-12-2001, 09:58 AM
I e-mailed Premier Power welder a couple of months ago and was told that the X has a "standard small case alternator with saddle mount." How about dual Optima batteries and a 170 amp alternator? That setup would never leave you stranded :) I have'nt gotten to serious about buying an alternator yet, but I think that high performance alternators are available. Of course, as low as the alternator is in the X you would probably ruin it during your first water crossing :( OffroadX has an interesting theory about swapping the location of alternator and the power steering pump. Apparently that is the way the Pathfinder is setup.
Synchro
06-12-2001, 11:23 AM
the other problem with the extremeair is just the shear size of it. it's HUGE. it's perhaps twice the size of the ARB compresor. so where would you put it?
i am running the ARB compressor right now and have been very happy with it. after Tellico this past weekend. i aired up all 4 32" tires from 15 psi to 35. i think each tire took 3-4 minutes. which is fine for me for the cost of the compressor and not having to modify anything substantial in my truck. (i had to relocate the alarm horn). would i like a faster system? sure, but for the moment this does great.
Mobycat
06-12-2001, 11:27 AM
ARB $300 20% 17 AMP
$300 for an ARB compressor??? Is that CDN $? I got mine for $195 at 4x4 Connection. I've never seen them for more than $210. $400 for the Extreme Air is US$.
OffroadX
06-12-2001, 12:19 PM
I don't know if you saw my post on XOC, but I'm not as optimistic as I was. Apparently the power steering pumps have an integrated bracket, and are not interchangeable. You'd have to buy a pre-01 Pathy pump, they list for $400, and good luck finding one from a junker. The alternator bracket for the Pathy alone lists for $200+ as well.
If anyone has the gumption to pull their bumper, grille, and radiator to have a really good look at things, it would be a start. I'm almost tempted, but the damn A/C condenser is the kicker to an otherwise simple exploration. Don't know if it can be moved aside without opening anything up. Otherwise it's just the tranny cooler circuit in the radiator and the coolant itself to be conscerned with, and I'm up for that if I can spare the time.
Brent
xterrabull
06-12-2001, 12:30 PM
Here's a couple compressor links.
The first is Macromotive (http://www.macromotive.com/search/goSearch.cfm?sid=BAEC08475F3B11D58E220090277E0A6A&tag=3.1) with some okay prices on popular compressors & some Viair compressors (no mention of duty cycle, but high PSI).
The second is Extreme Outback (http://www.extremeoutback.com/catalog.htm) with the Big Red Plus compressor, a belt driven compressor, and, at the bottom of the page, the ExtremeAire which I believe is the same as the BlowJax unit.
Philosopher
06-12-2001, 01:16 PM
Ain't that the truth. Because I've filled up other folks' tires on every run, I fill up my tank about every 2 or 3 months to the tune of $16 - not a big deal ... especially when I can be completely aired uip and ready to hit the pavement in about 5 minutes. Plus I could use the tank to run air tools if need be.
rhombus
06-12-2001, 04:57 PM
I got those prices (USD) from an article in FOUR WHEELER.
If the ARB is 150-200 then that is a big difference.
I guess my thinking was I would hate to burn up the ARB or be limited with it's performance for a extra $100.00.
It seems like a lot now but on the trail it would seem like a deal if it make the difference in a tough spot (even though this is unlikely).
CD has the ARB and I might just go that route for now.
Thanks again for the thoughts and ideas
warmonger
06-12-2001, 06:21 PM
Rhombus,
The Extreme Air and the Blow Jax I used are one and the same. I paid $335 for mine including the continuous duty solenoid and a circuit breaker that kicks butt.
But there is one thing I can tell you for sure, you WON"T squeeze that baby under your hood without some major surgery. Lest you have any doubts, ask either Synchro or Carlton about the size of mine. My system is a rocketship compared to the lower cost compressors. I just wasn't interested in listening to it run for 10 - 15 minutes while it built 125 psi. I also wanted air tool capability, something that came VERY close to being used on Friday at the Nissan plant when I got one heckuva big nail in my r/f tire. By some miracle I didn't lose air and was able to make it over to Wally World to get it fixed before Tellico.
As for mounting a battery where I mounted my air tanks, it will take some vivid imagination. It may be able to be done, but it will take some work to figure it out.
OffroadX
06-12-2001, 06:52 PM
A pair of the half-size 6-volt Optimas, 1 per side wired in series might do the trick...
Brent
rhombus
06-12-2001, 10:14 PM
Warmonger - Thanks for the info. I ordered an ARB comp today and will use that until I find a place (if i do) for a dual battery setup. The cost was cheaper than I thought and I can mount it under the hood. This will be the system that I will use for this summer and then maybe in the fall I will look at a better system.
I think that I might try and get a box made for the spare tire is.
This seems to be a good place to put some stuff and still have the cargo area. This will take time to figure out and I would like to have a compressor now so the ARB fits the bill.
OffroadX - I have been asking around about that and all people that I have talked with have not recommend using 2 6v batteries.
warmonger
06-13-2001, 05:16 AM
Rhombus,
I don't know that I would recommend using the spare tire well for a battery. I have put my truck on top of the spare tire so many times it would make your head spin. I can see using it for an air tank if you relocated your spare, but I don't think a battery would survive if you put all 4,000 lbs of Xterra on top of it. Just a thought.
The Warmonger
rhombus
06-13-2001, 07:51 AM
I also thought about that and would want the box that is built to be very tough (like a skid plate).
This would take some time to design and find a good mounting place (to take the possible weight of the truck).
I forget who mentioned it (maybe FSR) about a box with access from the inside of the hatch and sealed from below (for water).
My other suggestion for a battery was to build a really big hood scoop and tuck it in there ;)
I'm sure you know how hard it is to find a place for a battery.
I just wish that there was a stock place under the hood :(
warmonger
06-13-2001, 01:18 PM
Rhombus,
If you're willing to forgo some non-essential luxury items, like the cruise control, the alarm horn, fuel lines and the rest of the worthless junk piled up on the right side you can put it next to your other battery! :licker:
For that matter, save some fuel by ripping out the motor and putting an electric golf cart motor and 6 batteries. That way you qualify for a tax break and you now have sufficient power to run ALL the electrical accessories you want! (Just kidding!)
I believe sooner or later with all the accessories being added to our X's, dual batteries will become an issue. I just fixed before it became an issue. Anyone who undertakes a project of this scope, should be a well above average mechanic with a solid background in electrical design and implementation. Not only do you have to make the alternator work, you also have to make the dual batteries run the factory electrical EXACTLY as designed. This requires a great deal of planning and work. It also helps to have access to all kinds of neat electrical connectors. Otherwise it will be a huge mess of wires and if a problem does occur, you will have a tough time finding it if you don't have it set up right.
I can tell you the advantages and disadvantages to my system. First, it does take up some space in the back of the truck. Since I don't use the interior bike rack (Mine stay on the roof), this hasn't been much of an issue. You will lose the interior bike rack in the installation though. You will also have to rework the rear carpet to have access to the rear tie downs. It will also be a little harder to change your tire since the left side battery sits on top of the jack cover. There was no way around that because of the design of the cover.
The great thing about it is the fact that I now have a jump start any time I need it. My system uses a bridgable isolator that with the turn of a knob will jump start the main battery from the auxillary. It also allows me to run my high current draw accessories (lights, compressor, etc) with the confidence of not worrying about if I am wiping out the battery. If I do, I just turn them of until I recharge the battery. I can also get away with running more accessories on my main side for longer since I know in a worst case scenario, I can always jump start it from the aux battery.
Something was brought up to me this weekend by Richard that would hold true if you are winching on a single battery. Somebody told him that if you have the engine off, you will have more current available for winching. That is true, but, there is a caveat. If you have the engine off during winching, you can't provide assistance to the winch through the vehicles driveline. You are doing a dead pull. Yes, the engine will draw current while it is running, but when you consider the increased current necessary for an unassisted pull, the difference is overridden.
With dual batterie isolated, you have the full power of the auxillary battery going to the winch without the engine being a limiting factor. You still have a draw on the alternator, but even at 2,000 rpms, the alternator output on an Xterra is miniscule compared to the current your winch needs to continue operation.
These are all something to think about as you take on a project o this magnitude. It has its good points and bad points. You have to determine if for you, the ends justify the means.
Philosopher
06-13-2001, 02:22 PM
Jusy FYI for everyone - it is a common recommendation that if you run an electric winch for longer than a couple minutes, you should 1. keep the vehicle's motor revved up to about 3K RPM and 2. check the winch motor (by touching it with your hand) every 5- 10 minutes to see if it is becoming hot (warm is normal, hot means cut it off for a while).
ScottG
I don't think a running engine draws current from the battery. The alternator charges the batter when the engine is running. You can disconnect the battery while the engine is running and the engine will continue to run off the alternator. I don't know, am I missing something?
xterrabull
06-13-2001, 02:27 PM
Warmonger,
I probably need to be educated here: I was under the impression that with the car running, you could still use all the current the battery can supply, but you just can't charge it as fast as you use it if you exceed the alternators output (i.e., the alternator output is what determines the speed with which you can charge your battery); so, if you exceed the output of your alternator, you will drain your battery but at a *slower* rate than you would if the car wasn't running at all.
This was my impression, can you shed some light?
Philosopher
06-13-2001, 02:31 PM
True, for a little bit. Then the engine will die.
What I was saying is that if you don't run (rev) your engine somewhat while winching for a length of time, your battery will start to drain (happened to us in Kentucky when we had to winch an X for about an hour off and on without the engine revving - the battery light came on later that night).
ScottG
06-13-2001, 02:48 PM
I agree with you. I was responding to Warmonger, but you type faster than me :) With my old GMC truck, I could take the battery out of the truck and it would run fine. You just need to make sure the battery cables don't bounce around and touch each other. I haven't tried with the X, but if the engine dies, that's probably a sign of a weak alternator.
BTW can anyone tell my why when I try to quote one sentence I get the whole paragraph?
rhombus
06-13-2001, 02:53 PM
warmonger
Thanks for the tips. The issues that you mentioned are the same ones why I really want to have a dual setup in my truck.
The trouble is I'm a computer guy not a mechanic :(
You aren't also selling a How-2 for dual batteries with electrical plans are you?
:D
I have a guy at a 4x4 shop that can do the work for me I just need to come up with the plan.
I liked the idea of adding a box because then I would have more room for the install.
warmonger
06-13-2001, 06:21 PM
Your engine will run off the alternator until you hit a red light unless you keep the rpms up. On a factory alternator, (this is why they s@#$) the idle output is real low, to the tune of about 10 -15 amps output. This is not enough to run an electronic vehicle for long. You can shut off the A/C, radio, etc to conserve, but sooner or later, the alternator will put out insufficient juice to run the vehicle.
Older vehicles were not an issue since they had carbs and the only thing electronic on most was the ignition. This of course doesn't include the 1979 - up models which is when computer controlled autos came into their own.
As for the diagramming and photos, I started out shooting the project, but it became so huge that it would have sucked up every ounce of space on my website. Not to mention it became so technical that posting it in such a way that anyone could do it was impossible (I always try to write my how-tos so anyone can do it if they follow instructions).
I actually had to go in and repower my relay centers under the hood in order to power the PCM off of the new setup. I had to rewire the alternator, the starter and all other main power feeds based on where I wanted them to be fed from, the main or auxillary battery. The battery cables are 1/0 and 2/0 cable and all battery terminal connectors are hand soldered on and the cable custom made by me to fit. I preplanned what accessories I would be running off the batteries and made darn sure that wires were in place to make it work, including my voltmeter that reads voltage from both batteries at the flip of a switch.
It took me two months of planning and work to make it fly. I wish I could say it was a cake walk but it wasn't. It was expensive and time consuming, but damn well worth the trouble now that I look back on it.
