turbo kittuner04civic 11-16-2004, 05:25 PM i have a 4 speed auto honda civic ex...i want to have the fastest auto civic....piss all the others off...so far i did 2 1/2 custom exhaust...aem intake...and an ecu upgraded...i want to bore out my block and have a cutom hks turbo putting 24 psi's into it....what other than the turbo,wastgate, gaskets, blow off valve , pipes, pistins headers and high flow cat will i have to do to get the full power of the turbo...i asked around and not many know thanks civickiller 11-16-2004, 10:58 PM you want to run 24psi. dont give us a psi number, give us a hp number you want. sivic02 11-16-2004, 11:12 PM first off, i honestly dont think you know what your getting yourself into. Also what civickiller said is right, what your shooting for is horsepower, not psi. If you want the fastest civic around feeding it loads of boost isnt going to be the way to go. What your talking about doing is going to cost you more money than you have im sure, unless you just won the lottery you should reconsider. The way to make a fast car is in the gearing, sure its cool to say I have a 500hp civic but there is going to be someone out there running a 250hp n/a civic who will dog you simply because of the gearing. If i were you I would just do an engine swap, stage 1 turbo kit, and a new transmission with appropriate gearing. But if you dont want to listen to me or believe me and you still want a 24psi civic then i suggest you do it on stock internals. 97CivicX 11-18-2004, 10:23 PM how about a golden transmission with diamond bolts and pretty little swirls. yea Automotive Network, Inc., Copyright ©2012
