1987 Civic / no spark after rebuilt engine installedtowtrucks1 11-15-2004, 08:31 PM I am looking at a car for a guy who put a rebuilt engine ( 1500cc )in a 87 civic sedan. There is absolutely no spark at the coil. All the wires are plugged in and everything seems grounded where it has to go. I have swapped out distibutors, ignitors, coils, and I am up in arms. Is there a crank sensor on this car that anyone could tell me about? It is getting power from the ign when the ignition is on, but no power to the coil when it cranks. There is a blue wire on one of the two plugs that is next to a constant. should this show power when the key is cranking?? Sorry if I dont make sense, please help Figori 11-16-2004, 12:47 AM Is the ECU throwing any codes?? Is it FI or Carb? towtrucks1 11-16-2004, 09:22 AM I do not klnow where to look for thre ECU. where is it and how do I read the codes? Thanks for your help 87civicfranky 11-16-2004, 10:13 AM is the car f/i or carb????(agian...the same question.....) towtrucks1 11-16-2004, 03:51 PM Sorry it is carbuerated revhalzoo 11-21-2004, 08:16 AM check the coil with a multimeter, and check the wiring for bad wires. also is it not getting spark after the coil? hold the coil wire close to a ground and crank if you get a spark its not the coil towtrucks1 11-21-2004, 12:18 PM There is power going into the coil when the key is on ACC. When the engine cranks, there should be another wire throwing power to tell it when to spark right? I have one wire that has no power on either ACC or when cranking. No spark at the coil. towtrucks1 11-21-2004, 12:19 PM Is there a crank sensor somewhere that tells the coil when to fire? 87civicfranky 11-22-2004, 11:59 AM are you getting any negetive pulses when some one else cranks it???? if not then its the igniter.....i doubt the car has a crank angle sensor.......did you connect the wires to the igniter properly???did you check all the wiereings.....? try it out...holpe it helpes..... towtrucks1 12-24-2004, 09:36 AM are you getting any negetive pulses when some one else cranks it???? if not then its the igniter.....i doubt the car has a crank angle sensor.......did you connect the wires to the igniter properly???did you check all the wiereings.....? try it out...holpe it helpes..... When it cranks, one of the powered wires should be getting a neg pulse? I did not know that. The igniter is in the distibutor, isnt it? Thanks for all your help guys!! towtrucks1 01-09-2005, 11:17 AM Is the igniter the little black thing that spins in the distributor? 87civicfranky 01-12-2005, 06:36 AM ummmm nope...its the thing under it....the thing you say is the reluctor(somthing like that...)its under that....its a little black box with 2 plug type cables attached to it......well it also depends on what type of distributor it is... if its a toyo denso or a hitachi... but in this case yours is a hitachi... .............:)... o what ever! you get the point...dont wana bore you... towtrucks1 01-13-2005, 11:03 AM Thanks for all the time and help you guys gave me !!! I appreciate it!! Automotive Network, Inc., Copyright ©2012
